Cases BitFenix Shinobi XL review
Discussion in 'Hardware' started by stulid, 26 Mar 2012.
  1. stulid
    stulid What's a Dremel?
    30 Jun 2011
    Product homepage - http://www.bitfenix.com/global/en/products/chassis/shinobi-xl
    Case specifications.
    Packaging
    The case arrived in a solid cardboard box from Germany and survived the dreaded postal service very well indeed.
    The specifications are also found on the box.
    The packing foam used is very thick and suitably up to the job.
    Exterior
    The front and top panel have a almost soft finish to them thats very nice to the touch.
    The top front is where you find 4 USB3.0 ports, 1 quick charge port (Orange), microphone and headphone 3.5mm jacks with power LED and HDD activity LED above them, power and reset buttons.
    The rear has a 140/120mm fan mount with a 120mm fan supplied, 4 rubber grommets for water cooling tubes and nine expansion slots (it does support XL-ATX after all:))
    Dust filters underneath, the one for the PSU simply slides backwards, the other two are held in place by little plastic poppers that are easy to remove from inside.
    The case feet are screwed to the case chassis so wont fall off or rip off if you drag the case.
    Simple fan filter at the front, it just slips into place and held by some metal tabs, the case badge at the front can be easily removed and changed for different colours which I heard are coming as part of an accessories options along with different colour mesh inserts for the top and front of the case.
    Size comparison
    Heres a side by side against a Antec DF85 and Coolermaster ATCS840, its as wide and as tall as the ATCS840 but not as deep.
    Accessories and fittings
    So a simple instruction guide, 3.5" to 5.25" drive bay adapter and a bag of Black screws (with included standoff spinner which is a nice touch), cable ties, cable clamps and a speaker to attach to the motherboard header.
    Interior
    The holes for the standoffs are simply marked with a letter representing where they should be fitted and the guide for the letter codes is in the center of the motherboard tray.
    All the cable routing holes are fitted with rubber grommets, the roof includes a 230mm fan with the option of adding another or fitting 3X120mm fans.
    The front fan is also 230mm and there is also the option of 3X120mm fans.
    The drive caddies are simple squeezed and slide in and out, they support both 3.5" and 2.5" drives.
    The 3.5" drive bay cage is also simply removed by four screw from underneath the case and four screws in the 5.25" drive bay bottom.
    The PSU can be mounted both ways up and sits on rubber feet.
    The drive bay caddies are a bit wobbly and flimsy.
    30mm of room for cables, this is plenty for even the untidiest of system builders.
    Cables and connectors
    Two 19pin USB3.0 connectors each with an internal USB2.0 option, case front panel connectors and a female SATA power connector for the quick charge port.
    Completed build
    Plenty of space inside and behind.
    With the rubber grommets fitted to the cable routing holes it really does look better than what I could achieve with my Antec DF85 as seen below.
    Temperature testing
    Done some testing with the Antec DF85 (fan speed controllers all set to low) and this Shinobi XL, I used Realtemp to make a note of the four core temps then totaled them up and divided by four, the GFX core temp was taken using GPU-Z sensor feature.
    The i5 2500K I have was set to 5GHz.
    Antec Kuhler920
    Gigabyte GA-Z68XP-UD4
    Palit GTX570 (factory fitted twin fan cooler)
    Now it needs to be said that the Antec DF85 does have 5X120mm fans and a further 2X140mm fans in the roof so for the Shinobi XL to try and beat it was very unlikely, on the plus side its certainly quieter with it in the same location on my desk.
    I think the other reason for the higher temps is the front fan is trying to suck in air from a less than ideal route with the case front panel having a small opening underneath and two small strips of mesh either side at the front.
    Pros
    Looks great:)
    Plenty more fan fitment options.
    Lots of room and support for large GFX cards and motherboards.
    Great cable management.
    Cons
    Worse temps than other cases I own (but still acceptable)
    3.5" drive caddies are a bit flimsy.
    Overall 9/10
    Shirty likes this.
  2. stulid
    30 Jun 2011
    Looking very sleek.
    Sloth likes this.
  3. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    That is one good looking case. +rep for the review.
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    Only realised how wide it was when i saw the optical drives hidden in the middle on the last pic.
  5. stulid
    30 Jun 2011
    Been playing around all day with these,
    3X230mm and 2X120mm
    Here are my findings.
    • Stock cooling.
    • Added a single 120mm Spectre Pro fan in front of the PSU blowing air down and out, also bringing air in from underneath.
    • Three 230mm Spectre Pro fans fitted and running, the 120mm disabled.
    • All fans running.
    i5 2500K@ 4.5Ghz
    Antec kuhler 920 set to Silent mode.
    Palit GTX570 with factory fitted twin fan cooler @ stock frequencies.
    Ran Prime95 for 20 minutes.
    Ran Heaven 3.0 with the same settings as in the results thread - http://forums.overclockers.co.uk/showthread.php?t=18386056
    So as you can hopefully see, adding the 120mm fan bringing cool air in knocked a few °C off, and all the fans running dropped the temps on both the GFX+CPU.
    Pros
    Looks so pimp:cool:
    Lower temps.
    Cons
    Noise, its definitely louder with these fans than it is out of the box.
  6. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    That case is amazing looking. Alas I don't need to change as my current case does the job and I can't afford/justify changing my case xD
