Hardware Bitspower AIZ77ITXD Asus P8Z77-I Deluxe Waterblock Review
Discussion in 'Article Discussion' started by Meanmotion, 14 Oct 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    This is very tempting :). Looking for a Europe price / availability.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Am i having a Monday morning moment :rolleyes:
    I cant find the review of the EK Supremacy with a delta T of 32, the only one i can find shows a delta T of 43 for the EK Supremacy :confused:
  4. Combatus
    16 Feb 2009
    I'm assuming you've seen the Supremecy elsewhere with that delta T? We haven't tested the Supremacy anywhere other than in this review, which is a direct comparison between it and the Bitspower block using a specific set of hardware and our specific overclock settings.
  5. Corky42
    30 Oct 2012
  6. Combatus
    16 Feb 2009
  7. GuilleAcoustic
    26 Nov 2010
    This was the Precise mount, which is called "Supremacy precise mount", not the Supremacy CPU block :).
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    Great review Ant! You KNOW I've been waiting for this bad boy!
  9. nimbu
    nimbu Multimodder
    28 Nov 2002
    I gotta say, I have been very tempted to get this too.....
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    This, a high-end watercooled GPU... We're only a water-cooled compact PSU away from a ludicrously tiny high-end gaming machine.
  11. GuilleAcoustic
    26 Nov 2010
    Someone willing to mod a Flex ATX PSU ? :D
  12. Corky42
    30 Oct 2012
    So can i be forgiven for having a Monday morning moment :worried:
    Well at least that's the excuse im going to use for my everyday brain fart :hehe:
  13. GuilleAcoustic
    26 Nov 2010
    This morning is pretty rude IMHO, started by locking my account at work after 3 password failures, took the wrong train .... lets celebrate the "Brain fart monday" every Monday 14's :D
  14. Asouter
    Asouter --------
    18 Jan 2012
    Was there any fitting issues with the de-lidded CPU and the Bits-Power block ?
    Thinking about de-lidding mine, the only thing stopping me was having to buy a new precise mount supremacy.
    Is that not the case ...
    Thanks in advance
    Thicky Black Adder Thicky
  15. Cheapskate
    13 May 2007
    Kudos to Bitspower for putting this out. As crowded as that particular board is, I wonder why someone didn't do it sooner.
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Nice review Antony!
  17. Combatus
    16 Feb 2009
    Don't forget that de-lidding doesn't refer to actually running the CPU without the heatspreader. It just means you've taken the heatspreader off and applied your own thermal paste between it and the CPU core, and replaced it, which most people find drops the temperatures significantly. The EK PreciseMount allows you to use the Supremecy waterblock without the Heatspreader - that's all - which might lower them a couple of degrees more. You can't use the Bitspower block without the heatspreader, though - it's machined to line up with the daughterboard and chipset with the heatspreader present. Once you've secured the CPU into place, it's pretty much like a normal one to be honest as the lid is firmly fixed in place.
  18. Asouter
    Asouter --------
    18 Jan 2012
    Thanks Antony, very helpful.
    Great review, I sooo like the look of that Bitspower block, it just looks much cleaner than what I have fitted on my Impact...I know Bitspower have been posting renders for the impact on FB. Very tempted.
  19. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    That looks sweet, shame I can't go mITX for my main build!
    Again, thats a nice block.....
  20. Ljs
    Ljs Modder
    4 Sep 2009
    I bloody love it. WANT.
Tags: Add Tags
