Bitspower CPU Block Summit GT X?? Do you know it?
Discussion in 'Watercooling' started by AT0MAC, 5 Jan 2018.
  1. AT0MAC
    AT0MAC ~PC ninja~
    8 Jun 2008
    As some might have seen im trying to figure out a WC loop for my odd case
    One of the things I know I want is a full nickel block with high flow rate and good cooling.
    As im from Europe we dont have so many choices in great water cooling stores so one of the places I look is in Highflow.nl in Netherlands (I live in Denmark).
    They have a block called Bitspower CPU Block Summit GT X:
    I can not find any information about it anywere but it looks pretty sweet.
    Do you know it??
  2. TheMadDutchDude
    23 Aug 2013
    You can buy from EK directly if you wanted to use their products.
    The block will be fine. They’re all very similar.
    The reason you can’t find much about it is simply down to Bitspower being relatively new to that segment of the market compared to the likes of EK. They make superb products, so if you like the look...
  3. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    If you're after full nickel, then either the EK Supremacy as mdd suggested or watercool heatkiller is another option to go direct from the manufacturer. Check out aquatuning also, they're Europe based and have a heap of blocks to choose from.
  4. galvinD
    galvinD New Member
    6 Nov 2017
    It seems Aquatuning is one of the best place to check out.
  5. Vault-Tec
    30 Aug 2015
    The only place in the UK I could find that sells Bitspower is OCUK. I wanted to buy one of those hex res things but had no luck at all. OCUK do have a lot of older BP stuff on clearance, and had two of each rad they make but that was about it.
  6. 23RO_UK
    23RO_UK Hasta Mañana
    4 May 2010
    In the UK we are sadly neglected when it comes to the availability of Bitspower products :(
