Watercooling Bitspower! Where from?
Discussion in 'Hardware' started by Sparky1987, 15 Jun 2011.
  1. Sparky1987
    Sparky1987 What's a Dremel?
    9 Jan 2011
    Hi guys,
    Just a quick question, I've been looking at lots of your builds and see that you have chosen the bitspower matte black fittings.
    I've been google'ing the fittings and am having trouble finding a site that sells the full range of fittings.
    I've tried bitspower itself but the site that cones up has no link to there water-cooling stuff.
    Please can anyone point me in the right direction.
    Thanks.
  2. David
    7 Apr 2009
    Aquatuning do some, and Scan have a larger selection. I'm sure there are plenty of others too.
  3. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    So expencive :(
  5. Sparky1987
    9 Jan 2011
    Cheers guys much appreciated :thumb:
  6. Apocalypso
    15 Sep 2007
    Damn straight but they are pretty.
  7. Big Elf
    23 Apr 2009
    Specialtech will also order what you want but can take a while, my last request took about 2 weeks. Just get the code numbers from the Bitspower site to make it easy. Make sure you've a fat wallet.
    They are expensive but they must do really good quality control as I've never had a scratched or defective fitting yet although to be fair I've only bought 13 and 8 of those were blanking plugs.
  8. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    I bought four rotary black 90 degree angle adapters, and all four of them leaked. YMMV, I guess?
  9. Sparky1987
    9 Jan 2011
    What's the bitspower website that actually has the fittings?
  10. Big Elf
    23 Apr 2009
    http://www.bitspower.com.tw/
    I was mistaken. My dual rotary leaked if I put sideways pressure on but, there again, so do my Feser rotaries.
  11. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Hmmm, my Shitspower 45s leak with sideways pressure, and My Fesser dont.
    5 * the price, but only 4 * leaky.
    Polish a turd and it remains a turd.
  12. paz45
    paz45 What's a Dremel?
    12 Nov 2010
    i had 4 , same all leaked, put trusty old fesser back
  13. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
  14. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    bitspower should upgrade their site
  15. PabloFunky
    19 Sep 2010
    Hmmmm on that wcuk site, it shows bitspower fittings 4, not what id call a whole range?
