Cooling BIX upside down?
Discussion in 'Hardware' started by Coolrunnin, 1 Jul 2002.
  1. Coolrunnin
    Coolrunnin What's a Dremel?
    20 May 2002
    Just wondering, will a BIX work o.k with the barbs at the bottm? My rig will be neatened further if the tubes ar routed from the base of the rad :D
    I think it should but I was wondering if this might lead to air being trapped in the cross chamber :idea: Suppose I could always purge it outside the case then bolt it in when it's air-free :)
    anyone got thier BIX (or similar) with the barbs at the bottom?
  2. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    i thought having them at the bottom was the right way up :eyebrow: mine are on the side and it works fine. what pump? i think it would work fine any way up with a fast pump like the ehiem 1250 but a slower one might cause probs.
  3. Coolrunnin
    20 May 2002
    Yeh, reason I posted was due to the different pics I've seen of the BIX - roughly 1/2 and 1/2 barbs up/down. I think I'll try both ways and see what happens:)
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    as long as ur water flows through the radiator it wont matter
  5. Coolrunnin
    20 May 2002
    Thought as much, cheers Haddy!
  6. Haddy
    22 Jan 2002
    pip pip.....no clue what that means but ive always wanted to say it....
  7. Coolrunnin
    20 May 2002
    What oh old chap! - I've always wanted to say that as well :D
  8. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Yeah Coolrunnin i was think about that when i was setting up my rig. I would say if you properly bleed the system of air then you should be ok. Or.. making the water go up the rad, causing the pump to create lots of backpressure...so much so that the rad explodes and water drains into your HD's. Who knows? :D :D
  9. Haddy
    22 Jan 2002
    u do relize that in the radiator its like to giant u's connected to eachother.....and they are symetrical.....which means either way u put it the water will go up and down twice.....
  10. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Yes Haddy...i was just trying to be funny :rolleyes: :D
  11. Haddy
    22 Jan 2002
    sorry....too many posts on these dry humor uk boards....:hehe:
  12. Coolrunnin
    20 May 2002
    I was hoping that the rad would explode all over my M/B, G/c and possibly my LCD as well just to make sure that my rig's completely ****ed rather than some c****y repairable damage :D Maybe a bit of dry run eheim melting over my hand as well when try to fix it :rolleyes: :lol:
