Cooling BIX Xtreme 120.3 template
Discussion in 'Hardware' started by uwannabigmak, 20 Sep 2005.
  1. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    Does anyone know where I can find a Black Ice Xtreme Triple template? I don't need a grill, so I dont want to spend $30 just for the template. I don't trust my measuring skills nearly enough to do measure one myself.
  2. koola
    koola Minimodder
    11 Jul 2004
  3. uwannabigmak
    30 Dec 2004
    i mean all the holes and stuff. Ive tried a few times on test pieces, but they didnt turn out too well.
  4. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    104mm from center of the mounting holes for the fans and then the gaps
    is 15mm so you do in sketchup or cad 104 15 104 15 104 then your sorted :)
    morgan.
