Modding "Black and White" my In Win 101 Aorus custom build :)
Discussion in 'Modding' started by CustomRigs, 9 Dec 2017.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Black and White
    I hope you like my build [​IMG] if you have questions feel free to ask me [​IMG]
    Hardware
    AMD RYZEN 7 1700 at3,9GHz 1,32 Volts
    GIGABYTE AORUS AX370 GAMING K7 Mainboard
    GIGABYTE AORUS GTX1080ti
    16GB GSKILL TRIDENT Z 3200MHz CL14
    2x 256GB Crucial MX 100 SSD´s
    IN-WIN 101 Case
    750W Inter-Tech ARMOR PSU
    5 inch HDMI LCD Display Sensorpanel
    Watercooling
    360er Barrow Rad
    240er Barrow Rad
    EK WB Monoblock
    EK WB GPU Block
    Barrow DDC Pump
    EK WB Res X3 110mm RES
    Barrow HT Fittings
    6 120er NB E-Loops Black
    16mm Acryl Hardtubes
    TT Pacific Inline Tempsensor
    Pictures
    VIDEOS from the build
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    Nice. I was wondering how it'd look powered on with the red in-win logo, and it looks better than I thought it would. I think the 101 is a lovely case.
  3. CustomRigs
    8 Dec 2017
    yes i didnt change the led´s ... was not on my mind :D but its okay :D
  4. CustomRigs
    8 Dec 2017
    attention "RGB PORN" below this comment ;) hope you like my small Vid.
    Added a bit RGB lightning. Looks sweet too :D
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    oooooooooooooohhhhhhhhhhhh. Very nice indeed. Just one thing. I'm also a massive fan of the way you've took the photos? What did you to to take them? Can you change the title colour from black so it doesn't go invisible when using the dark style on the forum? :)
  6. CustomRigs
    8 Dec 2017
    what u mean ? the forum is not dark on my screen :D
    just a small cam (samsung NX500) a backround from amazon and two diffused lightspots :) and a bit photoshop ;)
  7. MLyons
    3 Mar 2017
    ........... :blah: The black title text is pretty much invisible on my screen due to me using the wonderful dark theme on the forums (It can be changed on the bottom left) Any chance you could remove the colour formatting on it so it can be seen by all? Also is 16mm the normal size for hardline tubing? It looks really thick in that first image.
  8. CustomRigs
    8 Dec 2017
    what is normal ? ;)
    you have the choice :) 12mm 14mm 16mm :) i take 16mm :) like thick stiff tubes :D :D :D
  9. CustomRigs
    8 Dec 2017
    i cannot edit my first post, if i try to change the textcolor to "non" i cant save it. get an Error
  10. MLyons
    3 Mar 2017
    Fixed, off the tubing looks thick in the first pic but normal in the others. Spooky stuff going on.
