Modding Black Cold Cathode question
Discussion in 'Modding' started by blueIce, 4 Oct 2001.
  1. blueIce
    blueIce The ICE man
    11 Sep 2001
    Does anyone know how much Purple light black lights emmit? I dont want it to mix with my blue ones you see...
    Cheers
  2. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    the blue one will overwhelm it but there's enough UV to light up UV objects with it alongside the blue.
    What you'll get is a normal blue cathode glow with UV stuff glowing as well depending on how close it is to the source..
  3. blueIce
    blueIce The ICE man
    11 Sep 2001
    PERFECT THANKS!
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    told ya :p
