Case Mod - In Progress BLACK HAWK CASE MOD scratch build (handmade) =Italian Extreme Modders=
Discussion in 'Project Logs' started by pccustom, 19 May 2019.
  1. pccustom
    pccustom Active Member
    12 Jul 2017
    Hi guys here my new project a scratch build hand made it's hard mod
    SPONSORS ARE WELCOMED enjoy!
    Here the project
    starting with aluminium bars to build the frame.
    [​IMG][​IMG]
  2. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    There are no reasons to miss your first scratch-build :clap:
    Pay attention to file rivets in that way, they could break!!
  3. Cheapskate
    13 May 2007
    Oh, yeah. Dot has a point. It would be better to add a dimple in the cover plating over the rivet.
  4. pccustom
    12 Jul 2017
    thanks for the suggestions I did some tests and the rivets hold up very well and other supports will be applied that will make the structure more resistant.
  5. pccustom
    12 Jul 2017
  6. kim
    kim hardware addict
    10 Jan 2016
    I like your modding...:dremel:
    pccustom likes this.
  7. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    See them cable routing holes...? Is something like that 'too much work' for hiding rivet heads to save having to file them flush?
    Only asking, 'cos
  8. pccustom
    12 Jul 2017
    it's a temporary job ..
  9. Sa mod pc design
    Sa mod pc design New Member
    7 May 2019
    The aluminum structure is interesting
  10. pccustom
    12 Jul 2017
  11. Cheapskate
    13 May 2007
    Coming along nicely.
  12. pccustom
    12 Jul 2017
    yes the work is so long...
  13. pccustom
    12 Jul 2017
    Cheapskate likes this.
  14. bolous
    bolous Member
    14 Nov 2012
    Good job! expect the final result
  15. pccustom
    12 Jul 2017
    Cheapskate and Dot_Kappa like this.
  16. kim
    kim hardware addict
    10 Jan 2016
    that's true modding mate :thumb: very clean work :dremel:, I like this innovative shape too, very original :rock:
  17. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Well-Known Member
    14 Sep 2004
    Gotta agree with kim love this mod :clap:
  18. pccustom
    12 Jul 2017
    here bottom panel with 12mm fans in exit holes.
  19. pccustom
    12 Jul 2017
    motherboard plate adaptor for water cooling clock
  20. Jeff Hine
    8 May 2009
    Image 2 in this post is just showing as an IMG placeholder... dunno if it's just me.
