Scratch Build – Complete ⭐ BLACK HAWK scratch build SPONSORED *HWLEGEND MODDING TEAM*
Discussion in 'Project Logs' started by pccustom, 19 May 2019.
  1. MADPC
    MADPC Minimodder
    10 May 2020
    great work! if the final result will be like the render... well well done bro! it's really easy to do? not for me... :)
  2. pccustom
    pccustom Multimodder
    12 Jul 2017
    no no, it's really easy trust me..
  3. MADPC
    MADPC Minimodder
    10 May 2020
    You make a final video of this too?
    pccustom likes this.
  4. pccustom
    12 Jul 2017
    sure!
    MADPC likes this.
  5. MADPC
    MADPC Minimodder
    10 May 2020
  6. pccustom
    12 Jul 2017
    top preparation with application of the handles.
  7. ciaognep
    ciaognep Minimodder
    10 May 2020
    so far excellent work but I think the most important part is the padding work.
  8. pccustom
    12 Jul 2017
    last cover closing panel.
    before applying the hinges and corner protectors I have to make sure that everything fits perfectly, the waste is minimal.
    I hold still with self-locking pliers so that when I make the holes nothing moves, it is very important
    if you err by 1/4 of a millimeter the closure will not match and it would be pain.
    also fixed the upper part of the hinge.
    the next step will be to insert the padding
  9. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Plywood should have been covered with skin, you can even artificial. It would be like a case for music equipment. :dremel:
  10. pccustom
    12 Jul 2017
    yes :) this type of cases is used for musical equipment that is often moved, they have a thickness of 1 cm of wood, I have not used the imitation leather to cover because the project would have cost so much and I don't want it to cost more than the mod, I took inspiration from the video of alex banks even though yours has a different but more expensive system.
    MADPC and censored_Prometheus_ like this.
  11. censored_Prometheus_
    26 Mar 2019
    Everything you do is expensive, you don 't need to save on packaging. :hip::grin::dremel:
    MADPC likes this.
  12. MADPC
    MADPC Minimodder
    10 May 2020
    I understood that this mod will have to be exposed and moved around, I think you have done very well to make a packaging !!
  13. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Build the truck now :)
  14. pccustom
    12 Jul 2017
    positioning of the padding
  15. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Can i order my box now!!! :rock::rock: 600 x 560 x 270 :D
  16. MADPC
    MADPC Minimodder
    10 May 2020
    super super super!!! :rock::thumb:
  17. pccustom
    12 Jul 2017
  18. censored_Prometheus_
    26 Mar 2019
    Oh no... Handle... :eeek:
    Why not parallel the length to the side of the case?:eyebrow:
  19. pccustom
    12 Jul 2017
    more logos will be addicted around the case..
  20. pccustom
    12 Jul 2017
    last passage lateral writings and fixing of the packaging.
    temporary fixing padding with double-sided tape this allows me to evaluate well and make changes
    I fix the foam panels with spray glue applied on both sides
    now it's really over ..
    [VIDEO]
    censored_Prometheus_ likes this.
