Cooling Black ICE Extreme II UK retailers
Discussion in 'Hardware' started by -Xp-, 2 Apr 2004.
  1. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    For my latest WC setup, I really want a Black ICE Extreme II radiator, however, the only place I can find that sells these little beauties is www.chill-tek.com , and I don't really want to buy from them, as they seem rather "inactive", shall I say?
    Does anyone know of any other UK resellers? I looked through all the links on the sticky, but no luck. I'm sure that one of you guys can help me out.
  2. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Hi
    If you want a good double radiator, head on over too coolercases and pick up a ThermoChill 120.2 they are just as good if not better.
    Link
    Description
    I have one there really nice radiators.
    morgan.
  3. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    I was looking at them. If I do choose one, then it will mean buying everythign from one site (less shipping). But I really want the bragging rights that come with the BIX2.
    Thanks anyway. I'll use your advice if nout turns up.
    Does anyone have a Kcal value for the thermochill 120.2? (can't remember what it's called, can only remember unit ;)).
  4. OneMadPoptart
    OneMadPoptart What's a Dremel?
    14 Oct 2003
    The bragging rights that come with a thermochill 120.2 would be much better than those from the BIX II when dealing with the sophistocated water cooler :cooldude: .
    Thermochill is top of the line, no doubt about it.
  5. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    As you were posting, I had a discussion with a friend about the radiators. He greed that thermochill is indeed better. For about £20 less, and better performance (testifed by three independant people), the thermochill it is! Thanks a lot guys. I lova ya all.
    Expect project log in the next few days.
  6. OneMadPoptart
    14 Oct 2003
    Looking forward to it :D
  7. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Sadly, some of the parts were out of stock...giving me a chance to ask another question before I buy.
    The Thermochill radiator used a 3/8" BSPT thread. I want to buy some nice brass barbs that all ow me to use 1/2" ID tubing on them. Wherever I look, they only seem to make 3/8" BSPT to 1/2" barbs in nasty blue plastic, not brass. Can anyone give me a link to some nice brass barbs for a thermochill radiator?
  8. Risky
    Risky Modder
    10 Sep 2001
  9. pauldenton
    pauldenton What's a Dremel?
    8 Feb 2004
    http://www.coolercases.co.uk/wc_fittings.htm
  10. keir
    keir S p i t F i r e
    5 Oct 2003
    seems coolerCase's si the place to get it from, I got mine from there. :)
