Black Ice - Finished.
Discussion in 'Project Logs' started by Guest-23315, 16 Apr 2006.
  1. Guest-23315
    Guest-23315 Guest
    Project :: Dark Water
    Blah... blah ..... blah
    Now…back to the Case..
    Nice Box, and the instructions are on the side.
    Rather wonky photo of front- Notice small flip up USB cover- to be replaced with small temperature read-out.
    Side panel with fan mounts- these will go in due-course and will be replaced with an acrylic window
    Suprisingly roomy case for really quite small dimensions.
    Yay!!! – 120mm Fan mount- meant to be 2 x 80mm , but a 120 is better!
    Right- Now time to go Downstairs and start with some modding !!!
    Good music never hurts…..
    First off, Taking out the HDD racks pop-rivets with a 4mm Drill bit-
    Nicely done.
    Quick blast with some sharp things-
    Todays work bench (my Trunk)
    After some Dremeling and filing
    After yet more filing-
    Now, all it needs is some blow-hole trim and a fan / fan guard.
    AJ.
  2. Guest-23315
    Guest-23315 Guest
    Project :: Dark_Water
    ..... Discussion Threads, they do exactly as they say on the tin....
    AJ.
  3. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    hey i have that trunk !
  4. Guest-23315
    Guest-23315 Guest
    nice- Its big and metal/ cardboard..
  5. Guest-23315
    Guest-23315 Guest
    More picceys tonight!
    Today - Sanding frount bezel.
    Marking out Were to make cuts for Rad.
    Contacting painters (you cant see photos of that).
    Another cut on my bl**dy finger.
    AJ.
  6. Guest-23315
    Guest-23315 Guest
    Right- Photobucket is being gay and has deleted some of my picceys, but im too lazy to re-load them so..here goes
    Today, i started with a little sanding and filling on the bezel-
    You probubly cant see much anyway- then the Painters told me that they would fully sand it all down, so i stopped.
    Naked case Porn!!!
    Got board an took the bottom off-
    I then tried to mount the first fan-
    but some bits of the fan guard got in my way so....
    From this-
    To this
    and finally this.
    AJ.
  7. Guest-23315
    Guest-23315 Guest
    Right, Photoucket is now semi-working-
    Moment of truth!!! It Fits !!! (looks wonky cos the back of the fan is broken (ie. not straight))
    It fits here too!!!
    Looking good with frount bezel!!
    Still needs Jig-sawing out thought!!!
    - now time for my favorite past-time-.....
    Cleaning up!!!
    Good Night People..........
    AJ.
  8. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    errr... I also have a mod called Dark water... :)
  9. Nova
    Nova What's a Dremel?
    28 Nov 2005
    hey hey, check out leeums mod on hardforum.com and maybe here, called moondust or sumtin like that, he mounted a dual 80 mm rad inthe front. i have a pair of chieftecs if you need any parts, both are forsale since i built a shuttle....
    keep up the work!
  10. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    He mounted a 2x120mm Rad upfront.
  11. scarecrow
    scarecrow What's a Dremel?
    4 Mar 2006
    sweet man. I am looking foward to see how this turns out.
  12. Guest-23315
    Guest-23315 Guest
    hokey kokey!!!
    seeing as the water cooling hard ware has been moved back to the wavemaster, i have put this project on hold for now, until i am sure it all works in the wavemaster.
    i may end up turning this into an air cooled mod but i dont have any plans for it in the near future.
    AJ.
  13. Guest-23315
    Guest-23315 Guest
    Right, time to re-start, ive now got a hole host of modding bits coming from www.kustompcs.com , including 2 x 4" Blue Cold cathodes, 2 x 12" Uv cathodes, a host of heat shrink and brading, some blow hole trim, a bulgin vandal swich and some 120mm LED fans...
    the should be here on Sat, so i can carry on the modding
  14. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    It show real promisde, what are the specs of the Pc your bulding? Will it be water cooled? OR just use a Zalman fan or a Artic Cooler fan? Its a great case the Chieftec design is great, especially with the metal grill on the lower section of the door, very industrial... any thoughts on modding that?
  15. Guest-23315
    Guest-23315 Guest
    Today i decided i would make everything in this case Black, or as dark as possible...
    I started off stripping the Fan Controller, so that its ready for painting...
    The Metal bracket after painting ( 2 coats of Matt with 800 grit between)
    With the Daughterboards in...
    And with the aluminium fascia and platic bits...
    I'm uploading the rest of the picceys for the other bits done.
    AJ.
    PS_ Its going to be a water-cooled COnroe rig with 8mm Alphacool stuff.
  16. Guest-23315
    Guest-23315 Guest
    DVD Drive... and Insides of Case
    I also took apart the DVD drive, and gave it 2 coats off Matt.
    The finish doesn't need to be amazing, just black so that it blends into the theme of the case
    Speaking of the insides of the case.....:
    This is only one coat, with a very thin layer of Primer. I'll eventually apply another coat, but only near the end of the project...
    Hope you enjoy...
    AJ.
  17. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Looks pimp. At some chrome and omg it will look fab! No blue though please :)
  18. Guest-23315
    Guest-23315 Guest
    i dont know anyone who can crome things for me......
    Blue is far too common, so i will mabey think about green instead...
    EDIT :: realised that i allready have the LCDs, and they are blue.....
  19. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Sweet, haven't seen anyone modding a chieftec ase for a while now. Good luck and Keep up the good work ;)
  20. Guest-23315
    Guest-23315 Guest
    WELL, at the moment, im just testing the drives and seeing how well they fit..
    Im really quite impressed with the Sliding rails design, it makes moving stuff so much easier. Im also finalising the hardware and watercooling for this proj. as well.
    I'll get some pics later on.
