Cooling Black ICE Micro CFM Info
Discussion in 'Hardware' started by Haddy, 7 Aug 2002.
  1. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    As I said, they're not BIX. Look at the HWLabs website and compare size and capacity.
    black ice pro
    black ice extreme
    also note, BIPro has several 'now with' or 'new'.
    The BI Pro is a remake of the BI Prime with 2-pass design for lower flow resistance. Doesn't actually affect the capacity much.
    Again, you can now buy the Black Ice 2 with 1/2" fittings and 2 pass design. But this is not the Black Ice Extreme 2. Check the cooling-solutions.de website
    http://www.cooling-store.de/csshop/index.php press 'Wärmetauscher'
    and compare the BI2 there to the one on the Nokytech website.
    http://www.nokytech.net/news.php?id_news=1603
    notice that one is 28mm thick and one is 45mm thick. Also notice that the BIX is 45mm and the BIP is 29mm.
    Sorry to be stubborn, just the way I am:lol:
    8-ball
  2. weazel666
    weazel666 What's a Dremel?
    12 Jan 2002
    just got one of those black ice micros today .. god there well cool .... shame about the size of the fittings tho .. only 1/4 .. nightmare ..... scratching away at the paint coating .. as u do ... and appears the fins are copper .. the chamber bits are alu and the shroud bit looks like brass .. i may be wrong about the brass .. wheren't they supose to be all brass and copper tho? i might have a imitation one i dunno ? doesn't matter really ether way i'm only gonna use it to cool air within my system .. once i got my chiller fully insulated
  3. Risky
    Risky Modder
    10 Sep 2001
    welded or screwed in barbs? Might do very nice for a rad on the aux loop of my planned piece of overspecing. But I'd like to rig it with plug-in fittings.
    EDIT: looked at the pic. No joy.
  4. jamicon
    jamicon What's a Dremel?
    26 Nov 2001
    you guys are right about the BI pro, shouldnt have doubted yous :)
    ive seen some site a while ago, selling the coloured BIX and linking to the BI pro page. so i guess this got me all confuesed.
  5. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    What is the difference between the BIX and BIX Rev. 2?
  6. 8-BALL
    6 Nov 2001
    1398342003
    It isn't a BIX rev2 it's a BIX2. designed to take two 120mm fans on each side compared to just one with the BIX.
    =double the heat capacity
  7. Haddy
    Haddy World Domination
    22 Jan 2002
    =~double the heat capacity
  8. relix
    relix Minimodder
    14 Nov 2001
    mmmmm...I was waiting for them to release something like this! Imagine having a BIX2 to show off... :eeek:
  9. 1398342003
    2 Sep 2002
    I have a BIX2, that's why I asked.
  10. 8-BALL
    6 Nov 2001
    1398342003
    What I meant was that there is a BIX Rev 2 AND a BIX2.
    They are NOT the same thing.
    As far as I know, nowhere is selling the BIX2 yet, si I will assume that it is the BIX rev 2 that you have.
    Sorry for any confusion caused.
    8-ball
  11. 1398342003
    2 Sep 2002
    I THOUGHT SO. Than that's a BIX Rev. 2
  12. Morphine
    Morphine weeee!
    23 Feb 2002
    will a micro be enough to cool just an XP 2000 ?
  13. mashie
    mashie The one and only
    15 Mar 2002
    Yes
  14. Morphine
    Morphine weeee!
    23 Feb 2002
    SWEET!
  15. Haddy
    22 Jan 2002
    Any proof on that mashie? Not that i dout the great mashie...
  16. mashie
    15 Mar 2002
    No proof but Swiftech seems confident to use it in their kit nowdays ;)
  17. Haddy
    22 Jan 2002
    lol 6 months later :p Deffinatly going to be a condenter in my next rig setup..
  18. mashie
    15 Mar 2002
    Better late then never ;)
  19. 8-BALL
    6 Nov 2001
    A BIM will cool just about anything. It depends on how cool you want them.
    The water will rise to a high enough temperature that there is sufficient temperature difference across the heat exchanger to dissipate the required heat load.
    For a larger or more efficient heat exchanger, this temperature difference will be lower, which is why larger rads can keep coolant at near ambient temperatures.
    A given radiator will have a thermal resistance, written as C/W.
    Thus, the required temperature difference between water and air will be the resistance multiplied by the heat load in watts.
    This resistance is determined primarily by the geometry and construction of the heat exchanger, but also by the properties and flow rates (turbulence) of both fluids, in this case water and air.
    So in the case of the black ice micro, due to its smaller geometry, the thermal resistance will be increased. This could be countered by increasing the turbulence of either fluid, (by increasing the water flow rate, or putting a stronger fan on).
    I hope this makes sense.
    8-ball
  20. Haddy
    22 Jan 2002
    Yea we were talking about this back when they first came out...Didnt see any tests on them back then...
