Scratch Build – In Progress Black N White - The incision 09/07/2011
Discussion in 'Project Logs' started by Carl97, 27 Oct 2010.
What should be the fan? (quiet)
Poll closed 6 Apr 2011.
  1. Arctic Cooling Arctic F12
    4 vote(s)
    33.3%
  2. Scythe Slip Stream, 800rpm
    8 vote(s)
    66.7%
  1. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Carl97...
    I know you spent quite a bit of time on your fan controller, but I'd suggest going a different route...
    Why not use PWM fans and build a PWM Controller? That way you're not limited to low power fans...
    Example... That is a 6000 RPM Nidec Fan -- 260CFM/520PA static pressure... And it is 4.45A (6.5A Startup)... The fan is connected stratight to the PSU for power (12V) and the controller takes care of the speed regulation via PWM signal.
    Example 2... That's a 6000RPM San Ace fan - Same 260CFM but not as high on the Static Pressure. It' is also rated for somewhere around 45W so it would blow your controller, and most commercial ones up... But since the fan is PWM... Just feed it 12V and control the speed via PWM signal.
    This is the place where you will find circuit layouts and a bunch of controllers built by other members as well.
    Hope this helps.
    xXSebaSXx
  2. Carl97
    Carl97 Sorry, for my bad english.
    7 Jul 2010
    Thanks!:rock: Yes, well you say, but I will make bigger hole in the steel plate.
    Thank you for the tip! But unfortunately I did not want to build a new controller ... This controller somehow to be controlled the PWM signal?:idea:
  3. xXSebaSXx
    21 Aug 2010
    For what is worth.... the controller I built cost me about $10 in parts and it took me no more than an hour to put together... So it's not a super hard thing to do.
    The controller I built (on the video) sends PWM signal to PWM fans and that's how I control the speed at which they spin. Think of it as a CPU Fan header, but with much more refined control... The CPU Fan header controls PWM fans, but it only increases/decreases speed in 10% increments whereas this controller gives you the full range.
  4. Carl97
    7 Jul 2010
    8800gts 640mb & waterblock :D
  5. Carl97
    7 Jul 2010
    Front panel 2.0
    I'm countined the front panel and I solved the "problem" of jack connectors:clap:
    3d plan:
  6. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Nice front panel! / Radikálon mikor látjuk?/:D
  7. Carl97
    7 Jul 2010
    Thanks!:D / Ma vagy holnap :read: /
  8. Carl97
    7 Jul 2010
    Hi, after a little break here I am again =)
    Arrived the cable sleeve :clap:
  9. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice color scheme, nice pictures :thumb:
  10. Carl97
    7 Jul 2010
    Thanks! The third picture is my windows background:lol:
  11. mav2000
    mav2000 In Training
    16 Oct 2010
    Looking great....
  12. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    were i you get the sleeve from
    nice build so far mate
  13. Carl97
    7 Jul 2010
    Thanks the comments:rock:
  14. Carl97
    7 Jul 2010
    hello
    It's a quick post :D
    I cleaning the wood and I made a small incision for a longer vga cards, but not finished:dremel:
    The power button and cable sleeving:lol:
  15. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Niiiiiiice button, I also have one like this with red lightning. Maybe we buy it from similar person?:thumb:
  16. Carl97
    7 Jul 2010
    Thanks! Yeah, I buy for atke colleague :lol:
