Graphics Black Ops upgrade requirements
Discussion in 'Hardware' started by ajay72, 19 Nov 2010.
  1. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    I still wanna cry over that CX400W being replaced by the CX430 :sigh:
    The "builder" series ain't made by Seasonic is it?
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Nope. apparently it's a CWT unit.
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Stock is still drying up. No wonder, it's an excellent little PSU.
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Getting one next month before stock is depleted. Did an upgrade on a Compaq presario this weekend using the cx400. Nothing less than perfection.
  6. ajay72
    ajay72 Lerning the basics
    19 Nov 2010
    Is a PSU easy to change?
  7. murraynt
    murraynt Modder
    6 Jun 2009
    It just takes time, not difficult though.
  8. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Yes.
    This is only if you choose to purchase a graphics card that would take your total power draw close to the amount your current power supply can give. There are many second hand/previous generation cards that don't need over 200W to stay happy!
  9. ajay72
    19 Nov 2010
    Thanks guys. Ordered a new CX400 PSU (figured I don't want to be restricted by something that is only £40 to upgrade). Then getting something like a gts 240? Is there anything else? My CPU? I figure there are going to be games coming out more and more that I'll need better parts for so hopefully these bits will see me good for a year or so.
    Next I'll be looking for a monitor with higher res.
  10. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Yeah, but I would bet most need more than 10A on the 12V rail.
    Most people only think about power (W) when it comes to PSUs, but amperage must also be considered.
  11. unknowngamer
    unknowngamer here
    3 Apr 2009
    You could get some second hand kit.
    I got a HD4850 for £30 on a whim a while back, should be fine for this game on modest settings (and still look better than a console over scart)
    And a decent PSU can be quite cheap if you buy one of the deals from Scan (usually weekend on a today only) an anteq Basiq 500 watt at £40 or so.
    So you're lookin at £70.
    Plus you might get £10~£20 on ebay for your old parts.
    Maybe £50~60 out of pocket.
  12. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Point taken.
  13. ajay72
    19 Nov 2010
    PSU changed successfully.
    I've read in other threads about a market place. Is this somewhere on this site or a reference to the general 2nd hand market place out in the big wide world?
  14. ajay72
    19 Nov 2010
    Just in case anyone searches looking for the same answer. I installed a 460 GTX yesterday and Black ops runs fine except some of the annoyingly frequent video clips which stall from time to time but I think thats a different problem.
  15. Marine-RX179
    24 May 2010
    As long as you are happy, that's fine I guess. But I seriously doubt your GTX460 is running at any faster than a 9800GT/GTS250/HD4850 at the moment with your current CPU. You could use something like MSI Afterburner to display your GPU usage while in Black OPs...I'm quite sure that it would be nowhere near 100% usage due to CPU bottleneck. See if you can get round to overclocking your CPU...it would definitely give you some extra frame rates, even if it's only a few exta fps.
