Modding Black paint and other Qs, please ans!!
Discussion in 'Modding' started by wywywywy, 28 Sep 2002.
  1. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Hi,
    Here are some questions that I hope I can get an answer from you guys. Thanks...
    I want to paint my HDD caddies matt black, so...
    1. Where to get good cheap spray can (UK)?
    2. Do I need primer for matt paint? Or just glossy one?
    3. How easy (or hard) does the paint come off?
    And other misc questions that I can't figure out...
    1. How easy (or hard) is it to cut aluminimum comparing to steel?
    2. What about acrylic?
    3. Is it okay to take the PSU case off and leave it as it is?
    EDIT: i.e. use it without a case
    4. Important question... is there anywhere I can buy those I/O shield (that sheet of metal that protects the PS/2, serial, parallel, USB, etc), PCI shield and drives mount? I've seen them in some distributors websites but not retail :(
    EDIT: look over the back of your case, see that metal cover that protects your I/O (PS/2, serial, parallel, USB)? Thats it.
    Please answer or I might die! Thank you very much in advance!!
    Cheers.
  2. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Halford's
    Primer would help.
    Depend's how hard you wanna scratch it, The best thing for plastics is Vinyl Dye spray from halford's or as they call it "Vinyl Paint".
    Easy.
    Messy but easy.
    No, you'll disturb the airflow cuts some small hole's in the top if you need to take air away from somewhere else..
    Not sure what this means maybe someone eles can answer.
  3. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Hi,
    You mean Halford's the car parts retail? http://www.halfords.com ?
    Their website doesn't show any spray cans...
    Thanks.
  4. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Yup you'll have to visit there store, but if your painting plastic try and get Vinyl Dye or "Vinyl Paint/Spray" as they call it, It's 9.99 a can but last's a while.
  5. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Found the I/O shield on OCS :D
    ATX I/O panel (800527)
    Sadly there is no Halfords nearby... guess I'll have get those graffiti spray cans from the art shops... colour wise they are good, but they are easily scratched off...
  6. m00min
    m00min What's a Dremel?
    6 Jul 2002
    i sprayed my mouse in matt black car paint from halfords without primer and i've used it everyday for over a year and the paint hasn't even scuffed :D:D
