Case Mod - Complete ⭐ Black Panther MOD for TT Season 1
Discussion in 'Project Logs' started by Deblow, 5 Jul 2018.
  1. Deblow
    Deblow Minimodder
    12 Dec 2013
    Now back to the main feature for this build, with this being the first time I've attempted to do something like this as part of a pc mod I needed to learn as
    progressed from step to step, I also wanted to make the clay stronger so I experimented with resin, couldn't find anyone thats done this before so I
    was glad to see it went to plan.
    The panther is very strong now and its a good job too, several very heavy rolls cinema posters feel from the roof rack and landed on it.
    luck for me the only real damage was to the tale and was't hard to fix.
    So after filling and sanding out all the cracks I did the resin, primer one last time and other sanding and then I painted it matt, gloss, and satin black
    so I could decide what a like best.
    ended up going with textured rubber paint.
    All thats needed now is the fine details painting, this will be shown in the final photos later this week
  2. Deblow
    Deblow Minimodder
    12 Dec 2013
    Its my first time using the Thermaltake Pacific C-PRO and I must say, I love them!
    makes sizing up the tubes and fitting them very easy.
  3. Deblow
    Deblow Minimodder
    12 Dec 2013
    For this build I made lots of covers from scratch to cover wires and sockets.
    Here's some of them.
  4. Deblow
    Deblow Minimodder
    12 Dec 2013
    Painted the front and also made some 3D printed claws for the neck.
    At the top will go the Black panther logo and along the bottom the TT/Deblow logos with the matching design I did shown earlier in the log.
    This is the black base, the chrome was still to be added.
  5. Deblow
    Deblow Minimodder
    12 Dec 2013
    I've also used "Wakandan" Proper name Xhosa/Swahili text in a couple of places.
    On the reservoirs and the customised 360 RGB panels mean for the side of the Rads.
    Firstly the reservoirs, again I used the design and patterns I did at the start and slightly changed them to fit the tank along with the added text.
    Can you guess what the text says? [​IMG]
    first test run with some clear water, Light set to RGB full rainbow mode at stock until you program them.
  6. Mike Shep TTW
    Mike Shep TTW What's a Dremel?
    17 Aug 2018
    In total awe of your work dude.
    Pleasure of meeting you in Leeds last year at CCL. Following you closely :)
    Keep it up.
    Deblow likes this.
  7. Deblow
    Deblow Minimodder
    12 Dec 2013
    Hi, thanks glad to see you here mate :)
    Final photos will be up in a day or so
  8. Deblow
    Deblow Minimodder
    12 Dec 2013
    Ok so the deadline is tomorrow, I need to spam you with some last photo log photos before I finish of the final shots for this build [​IMG]
    Took the RGB 360 RAD panels apart in order to make a thicker version that would house the text, made a new cover for it with plexi and leather.
  9. Deblow
    Deblow Minimodder
    12 Dec 2013
    The normal RGB Lumi lights are from the front panel, the Plus versions will be used everywhere else.
  10. Deblow
    Deblow Minimodder
    12 Dec 2013
    The main sponsors panel in progress, this along with every other panel including the fan covers are all magnetic so can be removed easy and swapped around from side to side.
    I was sent the normal W4 waterblock for the CPU that I fitted and modded, then discovered they should have sent the Plus version as its a great improvement in control and also the brightness.
    The only problem was that I had no time to mod this ones like I did the original, but it still looks great.
    This is the front panel with some airbrushing to assist with the lighting.
  11. Deblow
    Deblow Minimodder
    12 Dec 2013
    After what feels like forever! the Panther build is complete!
    Had some great fun learning new techniques, 3D design, clay and printing along with new cool ways to use the RGB lighting.
    The mod is following in my main style, black is always a great personal chose for myself and I like to try keep the case
    mods resembling the original case as much I can so this was a tricky one to plan
    with all the glass and the fact that its one of the main features I needed, wanted to keep it all and work with it.
    So on the front I used the glass to make a light up panther face using paints and RGB plus strips.
    I tried 3 different designs for the text and pattern on the front and went with the one that was the least in your face to try
    keep it clean.
    For the right side/back, i wanted to be able to use the advantage of glass to be able to see though the case from both sides,
    so I didn't paint it like I would normally, I made some 3D printed props to help give some depth and I cut the motherboard tray in half and positioned the motherboard hanging with the main rear ports facing down and central.
    all the wires were then hidden with custom made covers, plastic, carbon and leather.
    For the top, and very easy to spot and was the one thing i spent the most time on, the build log would give you a idea of the time
    spent on the clay sculpted panther but it was far longer in reality lol.
    I went a step further with the clay to help make it more part of the case, adding lights to the eyes that's controlled via Thermaltakes RGB controller gives me lots of options for the lighting.
    the panther can be positioned facing any direction and has a leather base.
    On the inside is where I did most of the other modding parts, first changing the RAD layout by making new mounts and removing the old ones, the PSU remains in the same place but a custom cover was made to hold the pumps and I also made some 3D patterns in clear PLA that I then spent hours gluing in place and also wrapping the other parts to block the light.
    I didn't have RGB reservoirs so I made my own, this is something i have been doing for 5 years now so its become very normal for me.
    Lighting was fun to play with and so were the fan covers, like the side covers all the fan covers are magnetic so I can swap them about from side to side and also do the same with the side covers.
    I always try do something new, something I've not attempted before so I'm happy this all went to plan even with the delays along the way.
    Good luck to all the other modders, from what I've seen so far its going to be a hard one to judge!
  12. Deblow
    Deblow Minimodder
    12 Dec 2013
      File size:
      277.9 KB
  13. Deblow
    Deblow Minimodder
    12 Dec 2013
    And without the fancy RGB lighting [​IMG]
    a18.jpg f3.jpg f4.jpg i04.jpg i05.jpg i06.jpg p2.jpg sb4.jpg sb5.jpg sb6.jpg
    _Prometheus_ likes this.
  14. Deblow
    Deblow Minimodder
    12 Dec 2013
      File size:
      438.1 KB
  15. Deblow
    Deblow Minimodder
    12 Dec 2013
  16. Deblow
    Deblow Minimodder
    12 Dec 2013
  17. Deblow
    Deblow Minimodder
    12 Dec 2013
      File size:
      248.8 KB
      File size:
      326.3 KB
  18. Deblow
    Deblow Minimodder
    12 Dec 2013
    Here is the Main video and also a extra one showing some more lighting options and the RGB plus setup/app.
  19. zak
    zak Build Clean people, build clean
    18 Apr 2018
    This is so cool man. I have followed you since TRON. I even built my latest rig using a couple tips you gave a long time ago. TRON will always be my fav, but this is awesome bro.
    Deblow likes this.
  20. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks Zak!
    Yeah I like tron a lot myself, always try do mods that I would personally like to use at home, unfortunately most the time I have no space to keep them all so they get dismantled eventually :(
