Black Shiny Silence
Discussion in 'Project Logs' started by Grunt, 4 Aug 2004.
  1. Grunt
    Grunt New Member
    4 Aug 2004
    Black Shiny Silence [updated] baybus led indicators developed
    Since the goal is to make the PC silent (and it already is pretty silent) just having 2 touchbuttons on the front of the PC isn't enough, one has to see the setting the fan has, because one cannot hear it. I took this in account when developing the PCB for the fan control, i made a 'sense' pin wich i can connect to another device.
    Today I made this device on breadboard, to see if it works.. and it does :) It's a fairly simpje device based upon a LM3914-N chip.
    Here's the total setup:
    To show how good the QT160-D sensors work, I taped the sensors under my glass desk. The glass plate is like 1 cm thick:
    And heres a movie of the thing in action:
    DivX, ~508Kb
    note:
    the led indicator is in 'dot' mode here, I can also set it to 'bar' mode in wich case it'll display a bar of leds that fills when the fan speeds up, instead of a dot (duh)
    note2:
    right now I only have one fan connected, and one led bar. The PCB you see has 2 controllers, so in my computer i will control 2 fans and 2 ledbars with it (4 sensors).
    Since I used an IRF520 MOSFET for the final stage, this controller is able to handle up to 9.2Amps (!!) per channel, so I could place like up to 45 fans per channel :p (yes thats overkill for ya)
  2. Xenocide
    Xenocide New Member
    25 Jun 2004
    OMG that's amazing.
    I don't really have a need for a quiet PC as i always have music on (even when im in bed :eek:)
    I need to get reading up on all of this, very, very impressed :D
    Well done
  3. toand
    toand New Member
    17 Feb 2004
    Wow thats really cool :D
    Keep up the good work!
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    update?
  5. Grunt
    Grunt New Member
    4 Aug 2004
    Ah, i thought nobody found it really interesting.. anyway i have since designed and etched the PCB's for the leds/sensors, so basically the baybus is complete. Will post pics of that shortly.
    Haven't had to much time to spend lately, so project is going slow..
  6. Langer
    Langer Jesse Lang
    24 Jan 2004
    not interesting??? are you mad...imho this project is one of the top three on bit-tech (the other two are Narcissus, and Metaversa)
  7. G4m3R_X3r0
    G4m3R_X3r0 New Member
    3 Sep 2004
    What about Hypercube & HP Res 2??? You can't say those arn't top aswell
  8. Grunt
    Grunt New Member
    4 Aug 2004
    Thanks for the encouragement, but now you're grossly exaggerating.. there are lots of better projects around, like the ones mentioned, or the truck, or the project grandiosa, the reactor core, Qbix watercooled cube, and so on.. tons of them.. only thing i modded so far was the fan hole and i designed a fan control circuit.. nothint really special, the watercooling stuff is all stock.
    But.. it will get better :dremel:
  9. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I def want an update, the touch controller looks pretty sweet and any info on what you used will be greatly appreciated. Plus I can't wait to see everything implemented as it is pretty advanced. Keep posting the updates :clap:
  10. epidemik
    epidemik New Member
    11 Sep 2004
    nice keep us posted :dremel:
  11. -EVRE-
    -EVRE- New Member
    12 May 2004
    Totally star trek :D
    you know how to make a chip control a fan, directly wired into the magnets so i could spin forward or reverse?
    Good work, cant wait so see the finished result.
    -EVRE-
  12. marcin_ps2
    marcin_ps2 New Member
    27 Sep 2004
    You have wrong instaled ram cooling for gpu
    not like this
    but like this
  13. Jipa
    5 Feb 2004
    Wow! Very professional-looking fancontroller 8)
  14. Hephaistus
    Hephaistus New Member
    11 Mar 2004
    very nice project you have going here. Keep up the good work. :rock: :rock: :clap:
    BTW can you show a photo of the back of your case because I can't understand how it works with a 120mm radiator and "the back of the motherbord" (the connections ) How do they coexist there????
    (i hope that you do understand wath i'm saying, because english and me....)
  15. Tech-Daddy
    Tech-Daddy New Member
    8 Oct 2003
    Grunt... please please please!!!! Bring back the updates on this!
    I am such a noob when it comes to circuit design and electronics...
    I an RAVENOUSLY reading this thread, and loving what I see!!!
    Keep up the inspired work!
    I have been considering a touch pad of this very type for my machine, so I am GLUED and subscribed!
    :thumb: :thumb: :thumb:
  16. Providence
    Providence New Member
    23 Jan 2004
    Wow, grunt, great work!
    I wanted to create a controller for my cathodes, LEDs, and fans, all in one, to fit in a CD-ROM case. You have no idea what kind of ideas this has given me!
    When you desodered the wires on your PSU, did you just desoder at the base of the wire, or from the bottom? I need to do this as well, but I don't want to botch it.
    And what program (and where can I get it) did you use for the PCB? Eagle something?
  17. PeteTheMagicBum
    PeteTheMagicBum New Member
    23 Jul 2004
    The PCB CAD software can be found here. I've been tinkering around with it and it is quite good.
    Keep up the great work, I wonna see how this turns out. :thumb:
  18. mod-ern man
    mod-ern man New Member
    12 Nov 2002
    Grunt, I agree with Langer's comments, great work :thumb:
    Please post more photo updates for us electronically challenged.
    Thank you
  19. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    That's a nice schematic there, hope the author doesn't mind you hotlinking it :wallbash:
    Nice work though, keep it up ;)
  20. Nexxo
    23 Oct 2001
    No, Langer's right. I think your project is very promising (and I built Metaversa, so I should know! :p ). The home-grown electronic baybus is great work! :thumb:
