Scratch Build – Complete Black Silence - passively cooled home theatre PC (COMPLETED+Final Pics)
Discussion in 'Project Logs' started by Bennibo, 27 Dec 2016.
  1. Bennibo
    Bennibo What's a Dremel?
    22 Oct 2016
    Hi everyone,
    im new to this forum, actually this is my first post. Im Benjamin from Germany and i would like to show you my latest work.
    I finished this project a while ago, but since the new one im planning right now is based on a few aspects of this project, i thought i show you this one first. I hope thats ok.
    My plan for this project was to build a silent, passively cooled home theatre PC for my living room.
    Ive had the components before i started this. First i used a Akasa Euler with an external Bluray drive, but that didnt work out as planned since the BD drive refused to work most of the time. Then i got a MS-Tech MC-80 with room for an internal BD drive, which worked just fine, just wasnt completely silent. So i figured i had to build my own case.
    The components used for this are:
    - DQ77KB Thin Mini ITX Mainboard
    - Intel 3220T
    - 8GB Ram
    - 128GB MSata SSD
    - Slot in BR drive
    At first i planned everything in CAD:
    a view inside
    the frame
    a detailed view of the heatsinks
    i used aluminum tubing and connectors by Alfer for the frame.
    the heatsinks are 160x50x40mm in size
    then i bend aluminum for the front part of the case.
  2. Bennibo
    22 Oct 2016
    next i worked on the cooling system.
    i used copper for the CPU block and milled the cutout for the heatpipes into the heatsinks.
  3. Bennibo
    22 Oct 2016
    does a moderator need to approve what im writing every time, or is it just because im new?
    edit: it seems like no one had to approve my post this time, it worked right away.
    next i made these aluminum parts, which will be used to clamp the heatpipes
    i cut a bunch of threads into the heatsinks, so that i will be flexible with clamping the heatpipes. i rather be safe than sorry...
    also i cut the aluminum parts in shorter, more convenient sections
    a short test if everything fits. it does :)
    also i started working on the lid. first i used a plate shear to cut a piece of aluminum, then used a hacksaw and files to get the shape i wanted
    next was to cut a piece a acrylic for the lighting of the case with a jigsaw. of course i had to try how it looks with a flashlight.
  4. amagriva
    amagriva Minimodder
    13 Jun 2009
    Mhhhhh...Scratch built and silent...Juicy!
    Deffo subbed!:rock:
  5. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Welcome to Bit Tech! This is very cool - especially the custom built heatpipe cooling! :thumb:
  6. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    That's freaky... I am (very slowly) working on something similar:
    I think your design is excellent. Passive cooling really is the only way to go with a HTPC. While I'm here, may I point you to a suitably dinky PSU solution?
    Sorry for crashing your thread... carry on!
  7. Bennibo
    22 Oct 2016
    Happy new year everyone!
    thanks amagriva and LennyRhys :)
    thanks. thats ok, but im all set with the hardware for this build. im using a dell power brick from an old notebook. ;)
    next i had to do a lot of filing, until the acrylic had the same shape as the aluminum. also i cut out the middle part.
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    This is very interesting, and looks very cool (pun...) :thumb:
  9. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I love scratch builds, HTPCs, and hand tools! Great start man! Keep it coming.
  10. Bennibo
    22 Oct 2016
    thanks guys! :)
    next, i worked on the buttom part. so again, first getting the aluminum in shape of the bend front part, then working on the acrylic.
    also cut out a piece for the back
    and of course another try with the flashlight. looking good so far. :D
  11. Bennibo
    22 Oct 2016
    it was time to finish the back. the cutout was made with a hacksaw and files.
    next i worked on the inside. the mainboard is mounted via standoffs the the case,
    the bluray drive still fits underneath the mainboard.
    then i started working on the mounts for the CPU-cooler. again with a hacksaw and files.
    not done yet, but getting there.
  12. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Looking very nice.
    Are your heat pipes pre-bent or are you custom bending them?
  13. Bennibo
    22 Oct 2016
    They came straight and bend them myself.
    i made a helper which worked great.
  14. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Very interesting project, nice work!
  15. Bennibo
    22 Oct 2016
    next, i finished the mounts for the CPU-cooler.
    also i worked on the front. i wanted to have USB-ports in front, but i didnt want any screws visible. so i made a plate which hold the USB-header and is attached to the main frame. once again, i only used handtools for this.
    after that i made the cutouts for the USB-ports and the optical drive in the front.
  16. Cheapskate
    13 May 2007
    Awesome.:D
    Please post you heat pipe source. Google is flooded with stock coolers last I checked.
  17. Bennibo
    22 Oct 2016
    i got the heatpipes at conrad.de. Im not to sure where to get them outside of Germany.
    next thing was to work on the power button. i didnt want it in the front, so i put it in the back, where it just fit.
    also i experimented with the finish. in this picture i sandblasted the front. it looks very smooth and clean.
    Cheapskate likes this.
  18. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Nice work dude :thumb:
  19. neilhart
    neilhart What's a Dremel?
    2 Feb 2011
    Very nice project. Have you evaluated if the Intel HD 2500 Graphics suit your needs and the cooling of the 35 W CPU has any margin? You may want to switch to a i3-3225 CPU, 55 W, but has Intel HD 4000 Graphics which should provide better video performance.
    Just a thought. Again I have enjoyed your log with all of the great photos.
    Neil
  20. Nexxo
    23 Oct 2001
    Here you go. UK based, but free international shipping. :)
