Scratch Build – In Progress Blade Mini MK II
Discussion in 'Project Logs' started by Defyant Mods, 2 Dec 2018.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Blade Mini MK II
    I decided to scrap the first build, I really wanted to be able to add a GPU to this case and change the cooling over to an AIO system.
    (For the sake of NOT starting a whole new thread just for this as it really was just a quicky case mod i'll edit this original thread to reflect the new build.)
    This time i went with the more Conventional SSF layout.
    Having the PSU/MB on the same side and the GPU/Hardware on the other,with room for a possible RES.
    The dimensions are the same with a little extra girth to allow me to add a 140mm
    front fan this time round.
    A much more basic and conventional layout for the MKII
    arduum and Cheapskate like this.
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Bookmarked this thread :D Can't wait for more!
    Defyant Mods likes this.
  3. Cheapskate
    13 May 2007
    With the cutouts of this set of blades, you can build an even smaller NUC rig. :naughty:
  4. InsolentGnome
    InsolentGnome Minimodder
    14 Apr 2015
    It never stops! LOL
  5. Cheapskate
    13 May 2007
    Indeed. He should be able to get a Raspberry Pi and then a USB hub out of the continued cutouts.
    InsolentGnome likes this.
  6. Defyant Mods
    14 Sep 2004
    The crazy thing is i prolly got close to another 100kg of acrylic a week or so back.... i really don't need to be using any off cuts.
    But at least i'm modding :D
  7. Defyant Mods
    14 Sep 2004
    Cheers m8 ty :thumb:
  8. InsolentGnome
    14 Apr 2015
    and don't forget a usb drive for the final build
  9. Defyant Mods
    14 Sep 2004
    Speakers next girls....then blade desk ..........calm ya tits!
  10. Defyant Mods
    14 Sep 2004
    Had a spare couple of hours after work today so got a fair bit done.
  11. Cheapskate
    13 May 2007
    I think you could do away with the case fans at this size, but I know it's more about the rgb.
    100kg of plexi: Next build should be fused layers that form an organic shaped mega-brick.
  12. Vault-Tec
    30 Aug 2015
    Woohoo side quest started !
    It's a mini me !
  13. Defyant Mods
    14 Sep 2004
    "Woohoo side quest started ! It's a mini me !"
    It sure it :) Side quests are all the rage now.
  14. Cheapskate
    13 May 2007
    As small as it is, you could 'fin' out the entire side panel. :naughty:
    Those magnets are a little too close to the board for me. At least you isolated the magnetic field with brass.
  15. Defyant Mods
    14 Sep 2004
    Cheers Cheaps , i'll still use magnets to hold the sides but prolly wont bother with a internal cover now with this new layout.
    A few minor tweaks to the design, taking a leaf from Blades original build i'll add a slider mount for the front fan/rad.
    This will stop the blades from covering the screws and clean the front up.
    Next tweak or 2 was for the GPU.
    Adding a slider lock mech for the Card. Another will be added for the front.
    A small slot was pre cut to allow the riser cable to pass thru.
    Not set in stone but to help exhaust air the PSU can be flipped... i may go with full mesh sides.
  16. Defyant Mods
    14 Sep 2004
    The layout is a lot more functional now, with hardware upgrades being a lot easier.
    TodMod likes this.
  17. Cheapskate
    13 May 2007
    Gonna be 90% cables. :thumb:
    Think you could add the gpu to the aio? (ack! acronyms!)
  18. Defyant Mods
    14 Sep 2004
    Tbh i have nfi about the aio on the gpu atm but lol ima have a good think about it :D1
    A quicky update,
    Ive re-trimmed the outer blades to suit the new design
    The modified blades are hard glued to the housing
    The last outer 2 blades are also hard glued the outer edges.
    Gluing them to the outer edges for a flush fit gives a cleaner look
    Adding the larger 140 mm fan has a better over all look and fill up the front of the case.
    MTC soon
  19. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I love that little retaining clip for the GPU!
  20. Cheapskate
    13 May 2007
    Looks like a racing toaster.
