Disaster Blew my power supply!!
Discussion in 'Modding' started by logicprobe, 4 Jan 2003.
  1. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    you could have jiggled a loose connection, jiggled being a techincal term for well. jiggling. It might have been enough if the PS was a ittle loopy to make it pop...
  2. Nitrous Bum
    Nitrous Bum What's a Dremel?
    21 Feb 2002
    Yeah whos to say what might have been shorted, I doubt that it had anything to do specifically with the light, there are soooooo many traces, sawder points, capacitors, etc on mobos that very likely there was a very small bridge gapped by your jostling of the wires, jostling being a technical term for jiggling.
  3. logicprobe
    logicprobe What's a Dremel?
    12 Dec 2002
    Yeah. But aren't these power supplies designed to be "fault tolerant". It should shut itself down if there is a problem. I may have mentioned here. The ps I'm using now one time appeared to get "shorted" from one of the 4-pin molex connectors discharging on my metal side panel as I put it on. The ps shut itself off. I pushed the cables back and put the side panel on and turned it on no prob.
    Maybe like what was said, it could have been a bad power supply, maybe the extra load. Since I can' tbe certain I think I'm just going to return the light and not try to do any light modding for a little while
    One other thing I learned is that since my life revolves around my computer (plus it's the only TV I have - tv card), I should have a spare just in case something happens to this one :).
    Anyone have an older p3 motherboard/cpu combo they want to sell? :)
  4. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    A power supply ALWAYS shuts down if you short something out. You just had a dodgy supply - I'd send it back if I was you.
    Even my crappy 300 watt supply shuts down if it's shorted :D
  5. pranks7er
    pranks7er mange tout
    25 Dec 2002
    is the computer still alright ? or is 2500 quids worth just went up in a cloud of blue smoke!!!:nono:
  6. logicprobe
    12 Dec 2002
    SOB Antec, I bought this PS so that kind of thing wouldn't happen! Ugh.
    Well, I bought it at newegg a couple weeks ago, so I just RMA'd it. I expect they'll just send me a new one.
    Maybe they should change the name from Antec TrueBlue to Antec TrueBLEW! :)
    My computer does still work, Pranks. I left it on all night running the 3dMark demo just to satisfy my paranoid about whether something was damaged. I consider myself very lucky! This equipment cost me a forturne. At least for my budget.
  7. Buttcrack
    Buttcrack What's a Dremel?
    29 Jun 2002
    enermax > antec, at least in my experiences. btw, if you want to save a few bucks, its really easy to swap the psu fans. mine is also packing clear blue led fans, but it didnt come that way :)
