Windows Blizzard, you annoy me
Discussion in 'Gaming' started by AndyGoldie, 22 Jan 2011.
  1. AndyGoldie
    AndyGoldie 60Hz for Streets, 144Hz for Sheets
    23 Dec 2009
    So I bought SC2 today, because I've realistically always wanted it and I thought I may as well get it today while I was in town. Got home an hour ago, installed it, fine, tried to activate code, not fine.
    Of course the best thing ever, the CD code doesn't work. So now I've spent 40 minutes trying to take a half decent picture of the CD key with my mobile because I don't have a camera. Fine good, sent it away. Now I'm just waiting for a response.
    *sigh*
    That the rant over, now for what I actually want to know.
    Can I play SC2 single player without the CD key? (I'm still downloading patches)
    and how long does getting a response take? (I'm praying it's not more than a few hours)
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Pretty sure the single player requires active online connection, so I would guess not :(
  3. AndyGoldie
    23 Dec 2009
  4. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    The code "doesn't work"? I can't see thats Blizzard's fault really.
  5. AndyGoldie
    23 Dec 2009
    They generate the activation codes and stick 'em on the box?
  6. B_HERB
    B_HERB What is this..A CENTER FOR ANTS?!
    22 Dec 2010
    They should be able to give you a new code over the phone. I bought Fable on PC a while back and had the same problem, so I called the company and they gave me a new code which worked fine, and everything was done offline because I didn't have an internet connection at the time. I think all the codes are pre-generated to the disc, so they can just give you a new one. However...different company and differnet time, so it may be different.
  7. AndyGoldie
    23 Dec 2009
    Sorry, probably should of mentioned this. Yeah I did phone them but the guy I talked to just said that I had to do it via email as they have to see my receipt and code.
    I didn't actually mind doing that, I just wish they would hurry up and get back to me. The fact they locked single player to having to be online is a bit ridiculous if you ask me.
  8. Zurechial
    Zurechial Elitist
    21 Mar 2007
    No, this isn't the case.
    Like a lot of games these days you have to log into the system and validate it once, but after that the game works fine in offline Singleplayer and you can save your progress, move through the campaign etc just fine without being online - Albeit without achievement-tracking.
    Without an active connection you simply 'log into' the game as a guest and play the game that way, though the validation expires every 30 days; necessitating an online log-in to re-authenticate.
    Either way, the game does not need a constant connection, it's closer to Steam than Ubisoft DRM.
  9. pingu666
    pingu666 What's a Dremel?
    24 May 2010
    thats odd, and it sucks :(
  10. Zoon
    12 Mar 2001
    Ah okay doesn't need online connection but still needs that first-time activation, which he can't do as he has no key :( Knickers :(
  11. Repo
    Repo What's a Dremel?
    12 Jan 2011
    What a ridiculous policy, lets really, really, really inconvenience our customers and yet deter piracy of the game by... umm... zero percent!
  12. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    I know this could be a stupid question, but did you try changing "Z" for "2", or "G" for "6" or "S" for "5", this happened with me when I realized I ahd put a "5" instead of "S"
  13. Draksis
    Draksis What's a Dremel?
    21 Oct 2009
    Honestly, if anything it actually increased the piracy of the game. I've heard of a few people cracking game security just to give the company in question the solid two finger salute.
    Personally what I can't understand is why Blizzard didn't follow the its WoW system for Starcraft 2: that is, game can be downloaded for free off of web site - go to on line store (or where ever) and buy key on line, and only if you want, you can buy the game physically.
    Honestly - this is the best "DRM" out there. Yes true, being online while you play a single player game is a bit irritating, but considering the alternatives that are out there currently - far better than any of the others.
    /2cents
  14. Pughy
    Pughy Fancy a game of Starcraft?
    21 Dec 2010
    When you sent the e-mail did you get like a response and a number? If so phone them and say hey, check 'whatever number' and sort it out.
    If not and you wanna play single player you should be able to use guest passes (which last for 7 hours) to play the singleplayer.
    To the post above, you can buy digital copies of the game from blizzard. But I believe you need an account first with the game to download it.
  15. Repo
    12 Jan 2011
    Indeed, the farce with Spore can't have been forgotten that quickly surely?
  16. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    I have never heard of a code not working! Strange stuff indeed - maybe get a trial code of a friend till they sort the full code out?
    Once activated you can play in offline mode- not that this will help you! :s
  17. obbawobba
    obbawobba What's a Dremel?
    29 Jan 2011
    how bizarre. I've never heard of that happening before. I wonder what kink in the system caused it? Anyway, that does suck but I'm sure blizz will give you a new code soon.
  18. skipperoo
    skipperoo What's a Dremel?
    17 Oct 2008
    It's ironic that things like this happening because of their "anti-piracy measures" actually increase the rates of piracy. Are companies really this blind or just stubborn?
  19. JoeK
    JoeK Minimodder
    24 Dec 2010
    Good 'ol DRM, making gameplay a pain in the ass for legitimate gamers.
    Online activation is a pretty common these days, so it's understandable really.
