Education Blocking Mobile Phone Signals
Discussion in 'General' started by .//TuNdRa, 24 Aug 2017.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Hi all,
    I'm hoping one of you will Out-Nerd me here;
    Bit of a fun one today - I'm testing a failure case for a mobile phone where, when it loses network, it'll fail to reconnect. Problem is; I need to be able to control when and where it loses network in order to figure out exactly what it takes to cause the phone to entirely fail.
    I've tried a couple of basic things already, making up a foil lined box that happily killed all signal on my Smartphone (Xperia X) But the device just shrugged, stepped down to GSM and carried on without a care.
    Anyone have any further ideas on what I could do to completely cut this thing off from signal? I've even thrown this thing into a Microwave and it still doesn't give up on connecting.
    Any help would be appreciated.
  2. RedFlames
    23 Apr 2009
    Turn Airplane mode on...
  3. .//TuNdRa
    12 Feb 2011
    I appreciate the thought, but this only happens when the device is meant to be connected and loses it, I'm not trying to turn off connections, just provoke a failure I know does happen.
  4. BigAde2072
    BigAde2072 What's a Dremel?
    12 Oct 2013
  5. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Drive out into the countryside.
  6. jrs77
    jrs77 Modder
    17 Feb 2006
  7. legoman
    legoman breaker of things
    28 Feb 2010
    Faraday cage?
  8. Guest-23315
    Guest-23315 Guest
  9. .//TuNdRa
    12 Feb 2011
    Device is annoyingly resilient, Microwave does kill signals on my smartphone, but this thing is apparently a tougher nut to crack than my smartphone, also checked; Microwave is working normally, heating outside to surface of sun while inside is still frozen, no problem here!
    Plausible, but long iteration time, this thing falls over once in every couple of tests, definitely keeping it in mind as a fallback if all else fails.
    Now just to find somewhere to source that sort of thing for a one-off set of testing, I don't routinely need to kill signals, just enough to tell the OEM I'm not making things up when I report the issue.
    Does work! Problem is purely a practical one, I'm testing a couple of different locations and I'd rather not have to lug a minifridge or Microwave with me for it, seems that it'll only work properly if the cage is Grounded too, for a relatively dumb phone; it's very resilient.
    I have considered giving up and seeing if anyone will make me a lead Box.
  10. wolfticket
    19 Apr 2008
    Windowed faraday bags are apparently a thing you can buy.
  11. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    Wrap in tin foil and drop into a metal filiing cabinet?
  12. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Faraday cages are surprisingly difficult to build, it's still the number 1 foolproof way of doing it though. Make sure you wrap with multiple layers (and seal very well, RF can leak in through tiny holes) and earth the foil - it will not work correctly if it is not earthed, attach it to some plumbing or something.
  13. Stotherd-001
    Stotherd-001 Minimodder
    15 Apr 2009
    I would open it up and break its antenna lines. Alternatively a local university might have a signal blocked room available? If they have any electrical research labs they'll probably have one.
  14. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Ditto any old military structures build in the war era. Anything with 3 floors or more; they tend to have double-brick reinforced walls, metal in the structure, lots of concrete. I work in one and my phones are all 0 bars inside on the ground floor.
  15. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    This is the most critical step that is most often missed. Also foil all sides, floor, ceiling, and walls. Conductive foil tape should help with the construction.
    Do you need to be able to operate the phone while it is without signal?
  16. gagaga
    gagaga Minimodder
    14 Dec 2008
    If it's testing when the phone thinks it's got connection, but not really, then use wifi - attach it to an access point then pull out the internet uplink cable from the back. The phone will still have a strong wifi connection but no internet. Our app developers took an age to deal with that setup (happens in conference centres with lots of WAPs but poor uplink).
  17. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Wouldn't sticking it in one of those EM bags that come with things like GPU's, MoBo's and other similar phone sized sensitive electronics.
  18. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Come to my place (Norfolk), none of that signal nonsense here boyo.
