Modding Bloo optical mouse!
Discussion in 'Modding' started by Oclocker, 18 Jun 2003.
  1. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    have a cheapo optical mouse and the left button bounces a lot - so I opened it up to check it and though should I try modding it blue?
    Have tried before without much success. Anyway I did and the result is below..
    2mins a blue led (3000mcd 3.6V) - some minor soldering and voila..
    full size pic at
    here
    tried it on the onyx worktop - some cats all work well and will just take my mousemat to try..
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Here's my blue modded optical mouse. I used an 8000 MCD blue LED connected straight to 5V to prevent it from dimming.
  3. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    or you could pick up an HP travel mouse
    its a blue optical. only like $20
    got one with my laptop and i love it, been using it so much i went back to a regular mouse and it feels huge by compairison
  4. Oclocker
    21 Jun 2001
    Now thats better cos of the translucent sides :)
    got a make etc?
  5. Oclocker
    21 Jun 2001
    Well maybe too small for my dainty hands :)
    Anyway the funs in the moddin isn't it - sacrilige to suggest a standard HP one here :)
  6. mcmad
    mcmad What's a Dremel?
    31 May 2003
  7. bard
    8 Mar 2003
    It's just a cheap Logitech one.
  8. mookie
    mookie very nawty<br><img src="http://mookie.org/i/avatar
    30 Jun 2002
    I got one of those cheap Logitech kinds. Made it white. \o/
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    I hope there was a resistor in there. :nono:
