Case Mod - In Progress Bloody - Lian Li V2120X Liquid Cooling by pociej
Discussion in 'Project Logs' started by pociej, 26 Jul 2012.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    looks great dude !
    I think that you should have the 24pin cable behind the res instead, doesnt look good like that in your case :/
    Edit; subbed
  2. pociej
    pociej What's a Dremel?
    12 Jan 2011
    I think there is not enough space to fit 24pin behind reservoir...
    Need to check it later...
    One more before Xmas... :)
  3. pociej
    12 Jan 2011
    Hey!
    Today just 2 screenshots showing idle & stress temperatures.
    Soon I will receive rest of cables...
    i7 @4.7Ghz
    2x GTX680 @1215Mhz
    3DMark11 P17111
  4. Guest-23315
    Guest-23315 Guest
    That Bitspower CPU block is pweeety...
  5. pociej
    12 Jan 2011
    Hey,
    small update today.
    So long after last one but what to do...
    Recently I received rest of needed custom cables.
    Still need to do few things like new SLI bridge, connection between GPUs and few smaller like change rest of green orings.
    More here: Picasa
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Not a fan of the sli connections, but other than that very nice build.
  7. pociej
    12 Jan 2011
    Hey
    Last time few things left to do but now all of them are done.
    SLI bridge, SLI connection, o-rings...
    This is it...
    More here: Picasa
  8. KoSoVaR^
    19 Dec 2010
    love this build dude :)!
  9. pociej
    12 Jan 2011
    Did small upgrade some time ago...
  10. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    That's an odd way to do the GPU piping. Cooling them in parallel rather than series?
  11. Hukkel
    20 Dec 2012
    I really like it. It looks like a clean build.
  12. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Parallel is better.
  13. pociej
    12 Jan 2011
    Thanks!
    Parallel looks better to me so I chose this way...
    And from what I know parallel results in better flow.
  14. Primum Agmen
    21 Sep 2012
    It's pretty marginal (1C if you're very lucky), but yes. It's just fairly uncommon to see on builds.
  15. KoSoVaR^
    19 Dec 2010
    I really like that red/black sleeve, where did you get it from ?
    Is it any near MDPC-x in quality ?
  16. spyplane
    spyplane What's a Dremel?
    12 Nov 2013
    Amazing stuff. I would love to see the back panel if you could please take some pictures of that. I am interested in seeing how you wired everything, as I am a complete noob at cable management.
  17. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Not sure if it's the same, but it looks like Teleios Fusion
  18. pociej
    12 Jan 2011
    My local seller calls this sleeve Scorpion HQ (black/red).
    Dunno if this real name of it.
    In case of quality, I had many samples...
    MDPC, Scorpion, Paracord, many Techflex and my top is Scorpion for colored and Techflex CC for black one.
    (and MDPC isn't THAT good like it is known in internet, I wasn't impressed...)
    @spyplane,
    I'm not that sure you want to see "other" side... :D
    It looks far away from we can see in front, but sure I will take a photo of backside when I will be doing some things with PC...
