Why use LEDS? cause they last longer than painted bulbs and are much brighter here is the bulb removed see the arrows? use that to release bulb.. As you can see the bulb is soldered - Grrrrr Here is a led pictured next to bulb for size comparison get a decent soldering iron
get some resistors solder it on the anode (positive leg) make sure u trim led as it has to be as the same height as the bulb all done!!!
That method was gay - so I devised a new one!! get a header plug from a pc solder it on! bingo ! and neat allows you to change leds easily!!! and colours!! test it for continuity plug in led and enjoy!
Re: Re: Blooooo led mod - LOL Maplins do a kit for 19.99 that I think that is. the kit is called the sk6 if you go into the tools section you should find it
where do you buy those.. could be intresting, considering thats the kinda bulbs my car uses.. -scoob8000
