Modding Blowolin' A ClearPC
Discussion in 'Modding' started by :: Phat ::, 10 Jul 2002.
  1. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    Ok... I'm truly crappin' meself over this one, You see I want to blowhole my ClearPC, but I'm worried as heck that I'm going to crack the acrylic or something, I need to drill an 80mm hole and a smaller 40mm hole.. I have 2 sharp holesaws, whats the best angle of approach? Drill a small pilot hole first then go slowly?
    If It cracks I'm gonna cry!!!
    Aaaanddd... as for finishing it off I persume sand it down with fine paper then use a drill buffer?
  2. MrDT
    MrDT fapfap
    14 Jun 2002
    I was drilling acrylic last nite (made a practice window etch using n00b screwdriver to scratch surface, damn I'm ghetto :)). Drilling that stuff is teh bad if u ain't using a drill press!
    Make sure u use a proper drill press and it's clamped down VERY sturdily. Acrylic just loves cracking, other than that, just make sure u mask off non-scratch areas.
    Good luck mate. Be afraid, be very afraid :worried: :eeek:
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    I agree, at least do a test piece with some similar material to make sure your process is sound or oooohhhhh. Just remember that when drilling or sawing acrylic to go sloooowwwwww. Pressure is usually the culprit to cracked acrylic.
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    why do you need a blowhole? It already has 2.
  5. MrDT
    MrDT fapfap
    14 Jun 2002
    Pressure = Crack
    RPM = Meltage
    If you have a drill with a variable RPM speed, slow that bugger down! I don't know if you've ever seen it happen Paul, but the heat from a fast turning hole-saw will kinda warp the other side of your hole. Result being LOTS of CAREFUL, PAINSTAKING filing :( :(
  6. :: Phat ::
    7 Jun 2002
    Topios Secretios mah friend.. topios secretios.....
    MrDT, you've seen the warehouse, don't insult me by asking me if I have a speed variable drill pphht, of course I do :D
    Yeah, I thought if I just to nice and slow, well not too slow and just let the weight of the drill do the work...
  7. MrDT
    MrDT fapfap
    14 Jun 2002
    I ain't seen no muthafudgin drill press anywhere in there boy!
  8. :: Phat ::
    7 Jun 2002
    No drill press but plenty of hand drills and my steady hands... :)
    I got a range of drills, though I think I'll use gringo's DeWalt drill... I could use the concrete muncher but It weighs nearly as much as me!!!
  9. MrDT
    MrDT fapfap
    14 Jun 2002
    I wish I had steady hands. Low blood alcohol level causes me to permanently have the shakes. Baccy cravings dunnae help either! :hehe:
  10. peteone
    peteone Minimodder
    5 Jun 2002
    I have the same case but not the proper tools for the job. Shame because a top fan looks well good in this case have you seen HI-TEK,s article over at modthebox he puts 3 extra blowholes in, might be worth picking up some tips off him.
    http://www.modthebox.com/clearpc4.html
    pete.
  11. jamnog
    jamnog Guest
    i used to clamp on ply with some felt but i agree with the idea of a drill press it would be a better oprion.
    also practice on a peice of plexy before you do the job i wrecked an awfull lot before i got it right.
