Blu-Ray playback advice
Discussion in 'Tech Support' started by martyp, 1 Mar 2009.
  1. martyp
    martyp What's a Dremel?
    29 Jun 2008
    Hey guy's,
    I've just installed Windows Vista as the primary OS on my Mac Pro. Now I was thiking if it would be possible to enable playback of Blu-ray movies within Vista with my setup:
    Mac Pro (w/nVidia 8800GT) > Vista Ultimate x64 > 30" Apple Cinema Display
    Now I know that the ACD doesn't support HDCP and I doubt the GPU does either. Althought is there any software packages availible out there that I could install to by-pass that problem?
    Or should I just forget about doing this with what I've got?
    Thanks in advance,
    Marty
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
  3. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Though it seems the trial doesn't support Blu-Ray playback. :(
  4. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    If you have a Blu-Ray drive then try AnyDVD-HD.
    Also although Cyberlink Power DVD trial may not support Blu-Ray playback, I beleive the free alternative "Media Player Classic - Home Cinema" will do so, I know it at least plays back .mkv files.
  5. Silver51
    24 Jul 2006
    D'oh.
    Sadly, I have a feeling there won't be an open source player as the technology needs to be licenced.
  6. martyp
    29 Jun 2008
    Thanks for the replies guys.
    I've not actually bought/installed a Blu-Ray drive yet as I wanted to make sure I'd be able to use it first.
    I'd be willing to buy a copy of PowerDVD w/Blu-Ray support to watch them on, but with HDCP I thought I'd need a 'back-door' approach to watch them. :worried:
    So you think it'll work ok though even though I don't officially have HDCP support? If so, I'll be adding the drive soon. :rock:
    EDIT: Looks like AnyDVD-HD will do the trick! Thanks for the link Delphium! :thumb:
    EDIT 2: Just ordered the Sony BDU-X10S drive from Scan since it came with PowerDVD BD edition. I'll update this thread when I get a Blu-Ray movie to test it with.
