does anyone know where i can get some blue acrylic panels to match the blue on the front of a cm atc 210? im going to replace the sides of my atc with it, and i wanted to know where i can get the same colour from, otherwise its going to look pap, thanx
i've heard that usplastic.com is a good place to get acrylic, and they do have flourescent acrylic sheets §§
neither of them will be a huge help unless you're looking to pay an arm and a leg for shipping..... you could make a new front panel using the old one as a template and then have whatever color you want or can get your grubby little hands on.... personally i think a smoked plexi front & sides would look schweet™
ive decided to make a lan box instead, and thanx to silverbullet ive found a pretty cheap supplier of the acrylic sheets i need, thanx neway
