Hi, I am looking for two identical keyboards for 2 machines. My requirements are that they need to be backlit, full sized but minimal edging (like a filco), only use one usb 2 port and ideally not £100. I don't even care for mechanical. I currently use a k70 but have had a k90 and a g710+ but am not that much in love with the corsair. Something a bit cheaper and lighter would also be nice. Any ideas?
ive just started using an element beryllium. Early days but it seems ok if you dont want to spend out on something like a ducky shine. ebuyer currently selling for £50 i think
2nd vote for the Ducky Shine. The 4 has been reduced as the 5 has just been released. Thin bezel and full size. Ticks all your boxes.
I got two of the above keyboards but having problems with both of them On my PC: P8Z77-I DELUXE - I get USB device over current, no keyboard present on boot and then it has problems when I connect the keyboard during the booted windows On my other PC: H81I-PLUS - the @ key doesnt seem to work Any ideas on how to solve the "USB device over current" problem on boot?
I realised that the amazon marketplace seller had previously sold the keyboards, someone had complained and left feedback about the same issue. The seller had received them back and then resold them to me! Grumpy face time waster.. They're going back now. I did like them alot however, I shall be buying a pair off of Ebuyer for £60. Thanks
Sorry to hear that. I hope you have better luck with ebuyer. That's where I got mine from and it's fine, save for something which is probably simple to fix - key presses don't seem to register in Windows after booting up unless I unplug and re-plug the keyboard. It's a very pretty piece of kit IMHO though and works nicely once it's going.
