Case Mod - In Progress BLUE DEVIL (HAFX Conversion)
Discussion in 'Project Logs' started by jojoharalds, 7 May 2014.
  1. jojoharalds
    jojoharalds Member
    30 Apr 2014
    hi everyone
    my name is jojoharalds and I am 28 years old, (new to this forum)
    í recently started my Casemod and thought I should share it with you.
    THIS WILL BE SPONSORED BY.
    Sent from my LG-E975
  2. GeorgeK
    18 Sep 2010
    Welcome to the forum. Just to let you know that I will be deleting your thread once you've had a chance to read this - I cannot PM you until you have more posts on here.
    The reason for me deleting it is that you need to have actual pictures of work in progress for a Build Log thread.
    GK
  3. jojoharalds
    jojoharalds Member
    30 Apr 2014
    I do have alot of pictures of progress, but since I'm doing it through my phone I didn't get a chance to upload them all, if you could give me some time that would be great,
  4. GeorgeK
    18 Sep 2010
    Ok - will do (just this once though as I'm feeling generous / over-tired :lol:)
  5. jojoharalds
    jojoharalds Member
    30 Apr 2014
    well here is the journey of this mod so far,
    first stripping the case down to the frame.
    custom from panel,
    custom top panel,
    custom back panel,
    custom motherboard tray,
    custom midplate/psu cover,
    [​IMG][​IMG][​IMG][​IMG]
    test fitting the radiator s[​IMG]
    [​IMG][​IMG]
    test fitting the powersupply wich coolermaster were kind enough to sponsor me with, (HUGE THX TO COOLERMASTER)
    [​IMG][​IMG][​IMG]
    now to the custom midplate(made out of 2mm aluminium, like the rest of it)
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    stay tuned for more.
  6. GeorgeK
    18 Sep 2010
    Very nice :) Just so you know, your first 10 posts might take a while to show up as they have to be moderated :thumb:
    Keep up the good work!
  7. jojoharalds
    jojoharalds Member
    30 Apr 2014
    Thank you,
  8. jojoharalds
    jojoharalds Member
    30 Apr 2014
    Frozencpu order
    fittings and more.
    [​IMG][​IMG]
    everything you might need for acrylic tubing,
    saw, heat gun, Monsoon bending kit, silicon tube, acrylic polish,
    and some more awsome stuff,
    [​IMG][​IMG][​IMG]
    this is my set so far(STILL EXPANDING)
    Alphacool Vpp655 assembly (ek dual pumptop)
    And the pumps fit perfectly into the psu cover/midplate(for a clean and satisfying look)
    [​IMG][​IMG]
    And some pci-e extensions from holland/geldfabriek.nu
    awsome stuff.
  9. jojoharalds
    jojoharalds Member
    30 Apr 2014
    EK SPONSORSHIP.
    Huge thanke you to ek water blocks,
    they were so kind to provide me with:
    360MM Coolstream PE (new edition of radiators from them)
    240MM CoolStream PE
    Ek csq pump top 2x
    Ek nickel pump cover 2x
    5L Ek uv blue liquid
    Thank you very much.
  10. jojoharalds
    jojoharalds Member
    30 Apr 2014
    custom backplate, making the cutout for 3 radiator(240mm ek)
    [​IMG][​IMG][​IMG]
    And here comes the preparation for mounting the GPU's, with extenders. [​IMG][​IMG][​IMG][​IMG][​IMG]
    And í also made the reservoir mount on top of the ssd's (didn't want to put them behind the motherboard tray, makes Cablemanagement easier and cleaner looking)
  11. jojoharalds
    jojoharalds Member
    30 Apr 2014
    and now to the painting (powdercoat) and overhaul,
    first the white paint(even painted the screws
    And the blue(I think it turned out great) like the colour ombination, same colour as on my car;-)
    [​IMG][​IMG]
    received my sleeves and some led,
    From ICEMODZ.COM
    big thanks for awsome sleeving, and fantastic led work.
    now putting installing 3pin adapters for more fan connectors.
    and putting u channel on the fan cutouts(for anticvibration and clean looks)
    Reservoir mount will be made out of 3mm thick acrylic, with some led
    behind. and white screws.
    also put led under the psu cover to light up the silver pump covers through the the blue acrylic Window.
    And since I will be using extenders, I will not be needing the triple slot ridge, and will tberefore exchange it for a dual slot bridge(save space and cleaner look)
    and also had to make a stability bracket for the GPU's since they are a little bit heavy on the back end. (made out of blue acrylic.
    Polishing the cpu block(EK SUPREMACY with smoked acrylic top)
    before. [​IMG]
    And after.
    [​IMG][​IMG][​IMG]
    That's all for now, keep u posted as soon I will continue, waiting on some stuff to arrive.
    Stay tuned.
  12. jojoharalds
    jojoharalds Member
    30 Apr 2014
    started on the assembly... [​IMG]
  13. jojoharalds
    jojoharalds Member
    30 Apr 2014
    this is getting along,
    And vandal reset and power button.
  14. jojoharalds
    jojoharalds Member
    30 Apr 2014
    [​IMG][​IMG][​IMG]
  15. trintragular
    trintragular New Member
    29 Oct 2012
    Thank you for the updates - looks like you've made some great progress. Looking forward to see where you go from here.
    Just wondering... will you be installing any dust filters on the intake/radiator fans?
  16. jojoharalds
    jojoharalds Member
    30 Apr 2014
    yes there will be dust filters on top and the front(since I am having some dustproblems on my THOR D3SK)
  17. jojoharalds
    jojoharalds Member
    30 Apr 2014
    starting on the loop! [​IMG]
  18. jojoharalds
    jojoharalds Member
    30 Apr 2014
  19. jojoharalds
    jojoharalds Member
    30 Apr 2014
    first tube done.
    many more to go.
  20. jojoharalds
    jojoharalds Member
    30 Apr 2014
    [​IMG][​IMG]
