Modding Blue LED power button
Discussion in 'Modding' started by keir, 25 Feb 2004.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    ok first off Im not sure where this should really go so dont have a great go at me, just move it.
    Im looking for a power button it is clear perspex and had a meal center, and I've seen it with a blue LED behind it, It looks really cool and I think It's look great on my Lian-Li.
    I've looked on these forums for ages, (I seen it ages ago) and tried google, but both with no luck.
    I'd like to know where I can buy one, UK please :)
    thanks
    .Keir.
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    I think you are looking for a Vandal Resistant switch, these are readily available (for a price) on http://www.maplin.co.uk they are really good, i use them myself
  3. keir
    5 Oct 2003
    no, its not a anti-vandal switch at all, lol
    its a power button with a blue light in it.
    :nono:
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
  5. keir
    5 Oct 2003
    I cant see it so I dont know :worried:
  6. Pricester
    Pricester What's a Dremel?
    25 Aug 2002
    As Malcs said, the most common form of illuminated switch mentioned on these forums is the Illuminated Anti-Vandal switch. Maplin do one, but it costs £15.
    The other version is the original Bulgin switch, which is available in more styles and colours than Maplin sells. They have six distributors in the UK, including Farnell and RS. I found the switch here on Farnel - £12.42 excluding VAT.
    Finally, you can do as SteveyG suggested, and follow Bard's guide. This may be the best bet for the Lian-Li, as with a little extra effort, you can ensure that the front panel is still easily removable. I'd go with that - assuming you can get hold of some scraps of perspex (or acrylic, or plexiglass, or whatever...)
  7. keir
    5 Oct 2003
    ohhh this is the one I had seen
    Thats great thanks :thumb:
  8. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    Yep. Those are vandal-resistant switches.
    -TX297
  9. Cannon^Fodder
    Cannon^Fodder What's a Dremel?
    13 Feb 2004
  10. my58vw
    my58vw Plexi Expert
    22 Sep 2003
  11. keir
    5 Oct 2003
    ohhhh they look good, cheers guys.
