Modding Blue LED's
Discussion in 'Modding' started by Cyberbob:-), 27 Jun 2002.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Whats best Blue LED's Diffused or clear? I'm changing my computer and CD drive's LED's. Also thinking about making an external Fanbus....... Made out of clear plexi with blue LED's inserted in it. What would be best to polish the edge of the plexi? I will also include my PC's reset button and power button. And maybe at a later date a LCD. Does anybody know of any tuturials of an external fanbus?................................. :rolleyes:
  2. lukemm
    lukemm What's a Dremel?
    5 May 2002
    im guessing its pretty similar to a normal fanbus but with alot more wire :/
    coz your taking the power from the computer.... to the fanbus...then back into the computer. could be interesting. GL
  3. Cyberbob:-)
    16 Jun 2002
    Interesting but very smart............... Don't you think?
  4. lukemm
    5 May 2002
    whatever tickles your fancy innit :)
  5. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    couldnt u just use a normally off transistor? hook it in line with the positive wire and switch 5v to it.
  6. G8way
    G8way What's a Dremel?
    24 Mar 2002
    Diffused LEDs tend to be a little dimmer than clear LEDs, and the entire LED looks blue even when it's off.. As for the external fan bus, you could just take the 12V line off a molex, split it as many times as you need to switches, and bring the wires back into the computer. Then, you would take all the negative wires for the fans, and hook them up to the ground line on the molex.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    an etxternal fanbus would be made the same way as a normal one. I would build a simple fanbus inside your pc then have the wires running out to switches externally. Then maybe get some of the black cable brading or spiral wrap to hide those hideous cables.
  8. G8way
    24 Mar 2002
    You could probably even use something like a serial cable or a parallel cable instead of just bare wires
  9. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    For drives etc... I'd use water clear LED's because usually they have a light tube type thing to shine through, so you want a smaller angle (clear lenses don't diffuse as much = smaller angle)
    But maybe for a fanbus you could get diffused LED's, I think they're easier to look at, because they're "softer", but of course not as bright.
