Modding Blue LED's
Discussion in 'Modding' started by Cyberbob:-), 10 Aug 2002.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Hi.......................
    Thinking about changing my LED's in my computer.....
    What would be the best Brightness for.
    1. Drive LED's
    2. Optical mouse
    3. Power buttons
    Phew! I think thats all, Tell me if I've missed some?:idea:
  2. Oh_No
    Oh_No What's a Dremel?
    5 Dec 2001
    drive led's and power button doesn't matter what brightness as they're just for show....the optical mouse however is a different story, tried to mod my logitech optical cordless with a blue one but no go :(, too dim... I recon you should try with the brightest available to you (probably > 3000mcd)
  3. Mooya
    Mooya What's a Dremel?
    14 Aug 2002
    i modified a optical mouse to blue LEDs. i had to use 2 blue ones both rated at 1000 mcd... with that done it worked for me
    good luck :D
