Modding Blue lights with a blue case, or green lights?
Discussion in 'Modding' started by Bboy_Jon, 6 Sep 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    For my blue raidmax that im modding, would blue led fans look better or would green led fans?
    The case is blue, and the inside will be black (or should i paint the inside somethin else)
    My lcd that ill wire is gonna be green (i COULD buy a blue matrix orbital, i dont feel like wiring mine up, nor cutting my bay cover)
    and my hdd light is blue, unless i can get a green 5 mm led
    what color should i use?
    also if i dont feel like wiring it up i COULD get one of these
    http://www.jab-tech.com/customer/home.php?cat=219
    prolly the vfd, whys it cheaper?
    But uhh ya coolerguys sells prewired hdd leds
    http://coolerguys.com/leprwco.html
    i can get the green, not too expensive, beats having to buy a pack of 4 leds or somethin and soldering, and heatshrinking
    so ya what to do green or blue lighting?
  2. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I'm all for colour continuity. Blue and Green don't really compliment each other very well. I would stick with the blue and work from there.
    Too many clashing colours make it look like a clown case despite the work you've put into it.
  3. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    theurgy right. you have to choose one color.
    you have to combining the light with the case color .
    do you have a window in your case?
  4. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    yup
    its a raidmax scorpio 868
    well blue lights with green sleeving looks awsome
    What your saying about sticking to one color, is like if i had a black case, i should get black lights
    or are you talking about the hdd led? i havent installed or soldered a blue led yet, its just that i have the blue led, no green leds
