Windows blue screen isue
Discussion in 'Tech Support' started by DanSonley, 14 May 2012.
  1. DanSonley
    DanSonley What's a Dremel?
    20 Jan 2012
    hi guys
    So my last mother board died on my so i have replaced the mother board and cpu. However it now is really unstable, as in it keeps blue screening witch is really not good. Are there any tools or ways of fixing this? i can imagine there being a windows file validate check or some other sort of diagnostic witch could come up with something. i thought i had fixed it but it is still blue screening. so i have run out of ideas of what to do. the error messages on the blue screen is always different. i cant see anything triggering it. it seams to be random.
    I have:
    I7 3770k
    Gigabyte GA-Z77X-UD3H
    assus Direct cu II geforce 570
    8 gb mushkin ram
    running on windows 7 pro 64 bit
    all help would be much aprreshiated.
    thanks
    Dan
  2. JPClyde
    JPClyde What's a Dremel?
    7 Dec 2011
    Check your memory as you've replaced your motherboard and CPU, are you using all your ram slots, like mine some motherboards become unstable when using all slots.
    run SFC /SCANNOW to check for corrupted system files.
  3. DanSonley
    20 Jan 2012
    thanks. yeah i am useing all the slots. so maybe that's why. i will have to try with some removed.
    i have never heard of SFC /SCANNOW so will google that now.
    thanks for the help though
  4. DanSonley
    20 Jan 2012
    sooo... feel like a noob haha running it now.
  5. DanSonley
    20 Jan 2012
    so its come up with this. witch am amusing is bad... XD
    Windows Resource Protection found corrupt files but was unable to fix some of them.
    Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
    C:\Windows\Logs\CBS\CBS.log
  6. JPClyde
    7 Dec 2011
    I would boot into the repair system from the CD then, so the windows isn't running.
    I didn't ask, have you reinstalled Windows after changing the motherboard and CPU?
  7. DanSonley
    20 Jan 2012
    ok thanks. i don't know why i didn't think of that. it seams fairly obviouse thinking now. thanks.
    yeah i reinstalled windows, i had a lot of issues wist doing so though. mostly revolving around only having usb 3 ports on my motherboard but that could be why.
