Case Mod - In Progress Blue Thunder: SILVERSTONE TJ07 + QX9650 + 3-SLI EVGA 8800 Ultra (11 may 2008 update)
Discussion in 'Project Logs' started by giorgioprimo, 20 Feb 2008.
  1. giorgioprimo
    giorgioprimo New Member
    19 Jul 2005
    Well, nithing special, just would like to make a system sharp and neat:
    Same pics of the stuff:
    [​IMG] [​IMG]
    tacking confidence with the dimesion to place radatiors and power supply:)
    [​IMG] [​IMG] [​IMG]
  2. giorgioprimo
    19 Jul 2005
    to place the radiators I wil use hole originally used from the screw to hold the HD cages
    [​IMG] [​IMG]
    took the imprint to make the hole in the rad, and made M3 edging
    detail to place the last screw of the 360 rad
    than used this ..."screw" to mount the radiators....
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  3. giorgioprimo
    19 Jul 2005
    well I have enough room for everything
    need dremel action here:)
    work-place
  4. giorgioprimo
    19 Jul 2005
    dremel cut:
    [​IMG] [​IMG]
    solution to place the HD in the main rack ;)
    testing HD placement
    [​IMG] [​IMG]
    looks fine
    to be continued
  5. Guest-23315
    Guest-23315 Guest
    Wow, this looks like it'll be a good un' :thumb:.
  6. MixWizard
    MixWizard New Member
    16 Jan 2007
    what mobo you intent on using for this?
  7. Guest-23315
    Guest-23315 Guest
    Some form of 680i or 780i.
  8. giorgioprimo
    19 Jul 2005
    EVGA 780i.
    680i doesn't support qx9650
  9. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Lot of stuff going into that case.
    Have fun!
  10. Fox the ripper
    Fox the ripper Pussy Lover
    29 May 2005
    Bella giorgio, great job, and i love your ultra:naughty:
  11. NysoO
    NysoO Handcrafted
    2 Nov 2006
    You have some nice things going on here. Not sure how the rads will handle all the heat though.
    Anyways, good job, keep it up! :thumb:
  12. samkiller42
    25 Apr 2006
    Wow, this is great, as i've been looking to buy this case myself, defo subscribing to this. Good job, well done.
    Sam
  13. jhanlon303
    7 Sep 2006
    Don't apologize for the English here. We come from everywhere! My English is bad because I'm from the US!
    Nice work, I'll watch this one.
    John
  14. NZ_mod_man
    NZ_mod_man New Member
    26 Aug 2007
    Nice work so far. Keep us posted.
    I agree with jhanlon303. This is an International forum so, any english is good english as long as we can understand what it is you are trying to say. ;)
  15. giorgioprimo
    19 Jul 2005
    reservoir positioning:
    this way ?
    or this way ?
  16. Guest-23315
    Guest-23315 Guest
    The first way, or net to each other somewhere...
  17. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I'd go with the second option... Makes for a better view of both reservoirs! :)
  18. WTF_Shelley
    WTF_Shelley The picture is wheeljack
    6 Apr 2005
    Im a bit worried that both raditors blow inwards, wont that cause a huge build up of heat by the pumps and PSU? Im worried that it will vent into the main
    body and cook the computer
  19. G0RD0N FAN
    G0RD0N FAN Jeff Gordon #24
    16 Jan 2008
    This is one to watch!
  20. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Agreed. If all the fans are mounted in such a way that they are all pushing hot air into the case, its not good. Change direction of the fans on one radiator.
    Also, speaking about the reservoirs. Try mounting them as high up as possible, as it will make the loops easier to bleed.
