Case Mod - In Progress Blue Thunder: SILVERSTONE TJ07 + QX9650 + 3-SLI EVGA 8800 Ultra (11 may 2008 update)
Discussion in 'Project Logs' started by giorgioprimo, 20 Feb 2008.
  1. giorgioprimo
    giorgioprimo New Member
    19 Jul 2005
    well, I evaluated this problem, and thinking on that.
    but because of the galaxy power supply have 1 big 130mm fan and another 80 mm fan, both pulling warm air out of the case, I supposed is enough. I have room also to add another 80mm fan pulling air out of the case.
    BTW after the first assembling will be done I'll be monitoring the temps on the down part of the case to see if it is ok.
    Have all the fan on the radiator is a way which i prefer aesthetically, and think also that the pump is designed to handle higher temp the real one into the lower part of the case.
    BTW if it will to high, after test, I'll change the fan side on the radiator
  2. giorgioprimo
    19 Jul 2005
    Dremel time :
    [​IMG] [​IMG] [​IMG] [​IMG]
    than start working to stealt the cable
  3. Hazza
    Hazza New Member
    25 Nov 2003
    Looking good! This has been really helpful for me - I was thinking about building a system a lot like this myself. Did that hard drive rack come with the case? Also, did you have to make the 5.25" mounting holes for it? Or was it already like that?
  4. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Good stuff.
    To be honest, I'd probably have the dual rad blowing in, while the triple is blowing out. That will equalize the heat transfer a bit probably. The heat coming off the dual will be negligible and really won't affect the triple's cooling capability, because you'll have the PSU exhausting as well. Try out different ways and see what works the best.
  5. giorgioprimo
    19 Jul 2005
    the hard drive rack is came with the case, and originally is positoened in the lower part ( were i'm placing the radatiaros).
    I didn't do any adjuntive holes for mounting, I just used the original hole and screwed in same 3mm spacers ( take a look to the pics )
    I would prefer finish first, and evaluate the effective temps, if somthing is wrong, I will change the orientation of the fan . Wanna waith because to change the fan orientation, cost me a lot of work ( umount the rad, redoing the hole, and prolly make some adjuntive holes to the case...)
  6. giorgioprimo
    19 Jul 2005
    with this special "thing" i made the hole in the back side of the mobo
    this is the result
    and, this is the solution to mount the little pump
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    prolly I iwll need to modify the pump-plate, to close the side of the case..
  7. Teknokid
    Teknokid Well-Known Member
    6 Dec 2007
    Looking good, i shall keep watching
  8. giorgioprimo
    19 Jul 2005
    INTEGRATION OF THE LIQUID COOLING
    probe placemente, cable management and some other details
    [​IMG] [​IMG]
    fan wiring and reservoir probe placement
    pump placement
    probes placemets
    general view
    [​IMG] [​IMG]
  9. giorgioprimo
    19 Jul 2005
    testing the loop with clean water ( still need to add 2 vga).
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    today something is arrived :D
  10. giorgioprimo
    19 Jul 2005
    swapped the 3 ultra with 3 new 9800 GTX, some other modification and mobo fully liquid cooled with anfitech blocks :) :
  11. giorgioprimo
    19 Jul 2005
    DONE !!!!!
  12. Jipa
    5 Feb 2004
    That's not your primary monitor on the last shots, is it?
    Good work with the case.
  13. giorgioprimo
    19 Jul 2005
    No :D LOL that's just one of my lab monitor....
    The blue thunder ( now at his howner house) is gonna be used with a DELL 30"
  14. Jipa
    5 Feb 2004
    Oh good, I've seen some guys on other forums buy SLI-setups for 19" screens and that really makes me one sad panda :D
  15. samkiller42
    25 Apr 2006
    Thats a very very nice looking case, And gives me alot to think about now that i have my TJ07, question though, did you leave the two 90mm fans on the rear? And whats the entire machine like for noise? As currently mines all on air, and with the exception of my two Raptors, its very very quiet.
    Again, nice work, and hope to see more from you.
    Sam
  16. giorgioprimo
    19 Jul 2005
    Yes i leaved the original 90mm fan (rear and top) but controlled by rehobus.
    About the noise, for my idea of PC it is not properly quiet, but for his howner it is really quite because before this rig, he had a single stage cooled PC for daily use, this one is ok for him :). And with all the hardware inside the rig I think is no possible to make it more quiet
  17. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    wow.... super case, super video card, super cpu,
    must have cost you like 4-5 grand
    really nice job
  18. Heero195
    Heero195 New Member
    12 Jun 2006
    Great looking system.. Love the specs, but have you thought about using just one display on the front of the case instead on the various thermal sensors. It would create a far cleaner look overall.
  19. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Nice case. Very nice hardware.
  20. Fox the ripper
    Fox the ripper Pussy Lover
    29 May 2005
    Great work Giorgio, your 3 Ultra are Amazing :rock:
