Modding BlueOrb wire modding
Discussion in 'Modding' started by MagicMikey, 17 Apr 2002.
  1. MagicMikey
    MagicMikey What's a Dremel?
    31 Dec 2001
    I have a Hercules Prophet GTS 64MB (GeForce 2) videocard. The stock fan for the GPU came with a 2 pin wire connector connected to the videocard itself as a source of power. I bought a BlueOrb, which has a 3 pin adapter on the end, and was wondering if it's a good idea to replace the 3 pin adapter with a 2 pin adapter so that I can plug it into the videocard...
    Thank you.
  2. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    assuming that the power requirements match it should be ok. Just make sure the draw of teh BlOrb is equal to or less than the draw of the stock fan. Off the top of my head I would guess that they are incompatible, but check the specs.
  3. nikon
    nikon What's a Dremel?
    11 Jan 2002
    id run it off a molex....dont take a chance harming your vid card....
  4. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    I don't know if the Blue Orb has rpm monitoring, but if it does, you could probably hook that into your mobo. If it doesn't, I would just cut the 3 pin off and solder on some wire and put in a 4 pin connector.
  5. MagicMikey
    31 Dec 2001
    Yes, I have it plugged to my motherboard now. I think I'll leave it like that too....thanks guys.
