Guide Blueprints Collection
Discussion in 'Modding' started by Djayness, 13 Oct 2009.
  1. Djayness
    Djayness phwupupupup
    7 May 2008
    I talked to Jezmck (the web dev behind the sketchup collection) and to Cheapskate about the possibility of starting a DXF collection for the modding community here at Bit-tech.
    DXF is a drawing format that is essentially 2d and you can send it to your printer to print components to scale. This makes cutting that radiator hole, that hdd bay, assembling that motherboard IO plate a hell of alot easier.
    Those of us who have laser cutters or CNC routers can also use the DXF files to cut out components with incredible accuracy.
    Its going to be a community effort to gather enough useful components for people to use and I have already designed several components in DXF that modders here would find useful.
    DXF allows you to take this...
    And turn it into this...
    So what do you have to do?
    1. Tell us if this would be something you would want to support
    2. If you design to scale components, you can make the DXF files available to the collection
    3. I dont have a three, thats it really.
    Based on community response, we will go ahead with this. With desktop laser cutters and cnc's going cheap and more and more people looking to print and cut components, this would be a positive step forward.
    Let us know what you think.
    Editor22 likes this.
  2. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    I'd make it a library for DXF- and STEP-files. 2D is good but 3D is sometimes better.
  3. matthewrblack
    matthewrblack What's a Dremel?
    23 Apr 2009
    Great idea, ill dig out what DXF files i have, mainly radiator layouts though.
  4. Cheapskate
    13 May 2007
    :lol: This is the first I've heard about this idea. It would be nice to have patterns that can be vouched for on accuracy. Who is going to host this?
  5. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Depending on the file sizes I possibly could (not got much space left), unless Jez wants to keep it with the SCC?
  6. Djayness
    7 May 2008
    Haha I meant you as in coming up with the idea of the dxf from sketchup files. Jez wants to host it and hes looking at adding dxf to the SCC as an option or creating an entirely new dxf library for us.
  7. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    I'm up to contributing a little bit here and there.
    Not really sure what people are looking for, but I think it'd be interesting to see what other people come up with.
  8. stonedsurd
    11 Mar 2009
    I would love if this idea came to fruition!
  9. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    This sounds like a great idea :clap:
    Maybe a rating system for each file? or just a comments section/forum
  10. Cheapskate
    13 May 2007
    If jezmek is putting this forward for SU import, there's another issue. All the files would need some additional object that could be used for a scale reference. Importing DXF into, well... everything that isn't CAD/CAM, loses the original scale.
  11. Djayness
    7 May 2008
    Well when you think about it, it wouldnt need to be a huge library.
    All it needs to have is default cad models to scale of the motherboard, psu plate, hdd holes etc etc etc and whatever the community creates.
    Its just a referrence point for people to take these designs and customise them to their own needs.
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    So, do you all think this is worthwhile? Do we have enough contributors/interested parties?
    BTW - Hosting files really is no problem at all, I have unlimited bandwidth, and I doubt somehow that the files will ever be as big as some of the .skp files.
  13. Editor22
    3 Jan 2009
    Defiantly worthwhile :) only saying that because I'm in great need of a PSU plate .dxf and there's none about.
  14. Cheapskate
    13 May 2007
    +1 on everything editor said.
    I don't think anyone wants my flattened DXFs. Most of what I have made was ripped directly from the SU library. (No true curves, etc...)
  15. Djayness
    7 May 2008
    Shotgun :p
    Anyhow ill email jez in the hopes that he takes this further.
  16. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    http://www.mediafire.com/?0ku5txkmomv
    There you are.
    Editor22 and Cheapskate like this.
  17. Cheapskate
    13 May 2007
    Snagged! and rep'd! Thanks!
    Also: I just realized this list can include custom PCBs!!
  18. Sleepstreamer
    23 Jul 2006
    You're very welcome :)
    I'd be totally cool with this idea, got alot of dxfs laying around. Also, I've got an OK upspeed to host a file server.
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    Yep, am happy to go ahead.
    Do you guys reckon I should set this up at dxf.jezmckean.com or something?
    Same code/layout as for the SCC?
  20. stonedsurd
    11 Mar 2009
    Yup, that would seem to be best.
