Guide Blueprints Collection
Discussion in 'Modding' started by Djayness, 13 Oct 2009.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Thanks Sleepstreamer, +rep :)
    Just an idea... maybe there could be 2 files for each item, like a .dxf and a .pdf? the pdf being something similar to MNPCtech's templates so you can open them in browser and print directly. would be nice for those of us who just need templates to cut around :)
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    Is the above something other people would like to see?
    This makes me wonder if there's a better, less specific, name for this collection?
    edit2: "CADCAMCOL"? CAMCompCol?! ModFiles? CAMFiles?
    BTW FYI BBQ: Software_that_supports_DXF
  3. Cheapskate
    13 May 2007
    +1 for DXF.jesmck.whateveryouwant.here. :D
    I'd pass on CAM files. Everyone will have different uses/needs that would require customizing the CAM. (bits, material depth, position, etc.) It would have to be some freaky files for a CAM to be useful.
  4. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    If there'll be pdfs aswell maybe "drawings.jezmckean.com" would be a more suitable name?
    In any case, one thing I'd like on this site is some kind of rule that all drawings should be made using info you can trust (like Intels official pdfs for example), or they should be previously machined and tested. This is the reason why I cant use the sketchup library, as it could just be some guy with a ruler who made it in 10mins and then uploaded it without checking it thoroughly.
  5. Editor22
    3 Jan 2009
    Indeed Sleepstreamer, that's why I suggested a comments/rating type system so if there is any bad or inaccurate files they can be flagged by the users instead of Jez getting a headache :eyebrow:
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    I'm keen to do the ratings thing - jQuery AJAXy thingy probably.
    I wonder if there's a more obviously technical way of saying drawings.
  7. Sleepstreamer
    23 Jul 2006
    Me stating the obvious as usual then :blush:
  8. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Why not call them templates?
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    'templates' is good, but still perhaps not techy enough.
    EDIT: man I sound picky!
  10. razerz
    razerz What's a Dremel?
    2 Aug 2009
    Blueprints maybe?
  11. Sleepstreamer
    23 Jul 2006
    I was thinking about that as well, but aren't blueprints for buildings though?
  12. razerz
    2 Aug 2009
    I don't know really, but after consulting Wikipedia it can refer to any detailed plan. Although you are right as well, the original (and maybe "true") meaning is for a architecture or engineering plan.
  13. Unicorn
    25 Jul 2006
    You got my vote on this idea! I'm currently designing component templates for CNC water cuts in AutoCAD 2010 and would be willing to contribute :thumb:
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    "Blueprints" I like!
  15. Sleepstreamer
    23 Jul 2006
    It's settled then :)
  16. Editor22
    3 Jan 2009
    Blueprints sounds good :)
    Does that mean its going to be something along the lines of "MBC" modders blueprint collection ?
  17. Sleepstreamer
    23 Jul 2006
    Any news on this? I've noticed the site is up, but it has the same content as the sketchup collection.
  18. jezmck
    jezmck Minimodder
    25 Sep 2003
    Progress can't be blisteringly quick I'm afraid - I have a job and a wife, and the take most of my time.
    It would be great if you guys could start suggesting categories...
  19. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    Well, I have a motherboard with the standard holes placed on it drawn up. Info taken from ATX specifications ver 2.1.
    So I would have to suggest a 'Motherboard' section :D
  20. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I'm a bit late to this party, but .DWG doesn't change size on import as long as it's designed to the right size you need it. ;) We had a similar problem with your exported files for the Nvidia Cube, but I fixed it for Bill to finally work his magic.
    .DWG....food for thought!
