Bluetoothspeaker V1 - Cnc - Wallnut - 40hz
Discussion in 'Project Logs' started by al_bundy, 13 Jun 2024.
  1. al_bundy
    al_bundy Minimodder
    18 May 2015
    Hi,
    the bluetoothspeaker V2 is based on the bluetoothspeaker V1. This speaker is smaller, but the frequency is similar. ~40hz. In this project I choosed a 2 way speaker with 3” woofer and an AMT + 3” Subwoofer and 1pc. 4” passiveradiator. Volume: 4l. So, much smaller than the version 2. Battery, amp and DSP is exactly the same. The speaker is based on the CT298. I implemented just the subwoofer. That’s it.
    Ahaeffects coming through in the first minutes of soundcheck. DSP almost not necessary. I never expect that performance of this small Speakers even the simulation called it. It was my first time that I worked with a DSP and I will never miss that. I plan a Bluetoothspeaker V3 already as a partybox with much more level and lower frequencies with a bigger battery.
    But lets check the pix of the version 1. J
    Pix:
    Gradient CR080
    Dayton AMT Mini
    3“ Subwoofer Tangband W3-1867S
    4” Passivradiator:
    DSP:
    BMS:
    Amp:
    Battery:
    Lets go:
    Lets have fun J
    https://www.youtube.com/watch?v=2QdzbhUeE80&t=1s
