Storage BluRay drive not reading discs
Discussion in 'Tech Support' started by talladega, 3 Dec 2012.
  1. talladega
    talladega I'm Squidward
    18 Aug 2007
    For the htpc I built I bought a laptop slot load bluray drive for it.
    It is a TS-TB23L. I think made by Samsung or something.
    I haven't used it much, but yesterday I was copying some of my blurays to my pc and the first one worked fine and then it wouldnt read any discs after that. After a bunch of looking for seemingly non existent driver updates and uninstalling and reinstalling it in device manager it still would not work.
    Finally I gave up and rebooted the pc to see what that would do and put in a disc and it read it. Awesome, I thought, until this morning I put in a different disc and it does it again. I reboot multiple times trying multiple discs and no go.
    Is it possible that a dirty lens would be causing this? Or some other kind of issue? Or maybe I just got a crappy drive?
    thanks
  2. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    probably got dust in it.. get a blu-ray lens cleaner disc.. I have one.. it works.. if it doesn't read.. then you got a dead drive..
    talladega likes this.
  3. talladega
    18 Aug 2007
    Looks like you were right. I had it in the workshop too much when building the htpc case. :wallbash:
    I opened it up and cleaned it out and now it works perfect it seems. Put in multiple discs a number of times and reads them all. Ripping a bluray as I type this.
    :thumb:
  4. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Edit: seems problem has been solved :D
  5. talladega
    18 Aug 2007
    actually I ran into issues again last night. I am not sure why it does this but I know how to 'fix' it.
    What happens is it will read any disc and work great, but after a disc has been in there for a while (when im ripping it to mkv) I eject it once done and then it wont read another disc. to 'fix' the problem I power down the htpc completely and power it back on and it then reads discs perfectly again.
    I think it was a bit dirty, but that isn't the issue anymore. is it possible that it is going to sleep or into some power save thing?? it will spin up the disc a bit for a few seconds and the light flashes a bit, then goes off.
    Seems more like software than hardware, IMO.
  6. fdbh96
    29 May 2011
    Can you roll back the driver to a previous version?
  7. talladega
    18 Aug 2007
    Can't. I looked at what driver it is using and its just using a generic microsoft cd rom driver.
    Anywhere I can get a newer driver?
  8. Gaming_freak_10
    5 Jun 2010
    What brand and model is the blu-ray drive? I can look it up for you?
  9. talladega
    18 Aug 2007
  10. Gaming_freak_10
    5 Jun 2010
    Checking now.. *links up to Skynet to request assistance*
  11. Gaming_freak_10
    5 Jun 2010
    'dega, Try this linky
    I'll keep looking.
    Found this one as well.. Lemme know if this works.. *disconnects from Skynet and goes into sleep mode*
  12. talladega
    18 Aug 2007
    Tried that Microsoft Fix It thing. Didn't work.
    The driver listed on that site is what I currently am using. :(
    How can there not be a newer driver?
  13. Gaming_freak_10
    5 Jun 2010
    *boots up* What? Oh man.. *mutters* Sorry 'dega.. looks like that drive may be duff.. do you have any other blu-ray drives??
  14. talladega
    18 Aug 2007
    no other drives. i guess i'll just keep using it till it totally craps out.
  15. Gaming_freak_10
    5 Jun 2010
    Did the drive fail yet?
  16. talladega
    18 Aug 2007
    nope, I've ripped over 40 blu rays to my server so far. I have to do a full shutdown and power on after each one though. But it works.
    2 of my blu rays didn't work though... :( but I think thats the disc not the drive. Too bad I bought them quite a while ago, I don't think I could get replacement discs could i?
