BMB - Burning Mortality Box
Discussion in 'Project Logs' started by Klekkus, 1 Mar 2006.
  1. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Sponsors:
    Bilxtra, Mo i Rana
    - One fake bulgin buttom with out light
    3DfxCOOL.no
    - 6* UV katodes (30cm) plus inventors
    My School
    - Pays 200 NOK on the project
    Sketchup drawings
    Gonna engrave flames on the sidedoor plexi pluss a part of the logo.
    Everythings here are going to be upside down
    The front are gonna be almost the same, ony a display are coming later and a "bulgin" buttom are gonna be mounted in the front
    Topwindow are gonna be the same shape as the sidewindow. Only the flmes are gonna be engraved on the top.
    Hardware:
    - MSI KM3-M (M-ATX mainboard)
    - AMD 2000+ Athlon @ 2,1 GHz (Load is a little over 40c°)
    - 2x 256mb Crusilal DDR-SD memory with CL 2,5
    - A old Soundblaster soundcard
    - integrated GPU on 32mb (will soon be a FX5500 on 128mb)
    - 20gb Firebal OS disk, 120gb WD disk
    - LG DVD-RAM burner
    - Floppy
    The case that's going to be modded:
    Any coments?
    Discussion tread
  2. Klekkus
    5 Nov 2005
    Tools and stuff
    Things bought from Biltema
    Drill, jiggsaw, files og drills
    Dremel and a flat sander
    Update 27.02
    Ripped the case for plastic
    Turned the case upsidedown
    The backside, gonne be a 120mm fan there
    The front ATM, not when I'm done with it :dremel:
    My friend in action, I did 90% of the cutting. Strange I'm not at the picture.
    After cutting
    After som grinding, sanding and my niddle files.
    The sidedoor without a window are almost sanded down.
    Hmm... We forgot tho take pictures of the sidedoor, I'll throw some pictures in the next update of it when I'm done working on it.
    Any coments?
    Discussion tread
  3. Klekkus
    5 Nov 2005
    Update 28.02
    The bottom sanded down
    Driling the holes for screws for the plexi and for the aluminium plate I'm laying under the sidedoor to use some bondo to will the holes in the door.
    Steffen cuting wrong in the sidedoor :x
    Finish with cuting the alu and I have sanded the door down.
    Any coments?
    Discussion tread
  4. Klekkus
    5 Nov 2005
    Update 01.03
    Some bondo should do the trick :D I used silicon to gleu the aluminium to the steel ;)
    Looks like we dont need to sand it more before painting :D I used p80, p240 and rubbigng compound.
    And we was also finish with sanding tho other sidedoor :D almost clear for painting.
    Any coments?
    Discussion tread
  5. Klekkus
    5 Nov 2005
  6. Klekkus
    5 Nov 2005
    Update 02.03
    Took some stuff from home with me, paint, holedrill, paint, tape and some 8mm lexan
    Found some sleeving i had laying around
    Finaly after much sandin i can finaly see some metal :)
    Then i started on the fan hole in the back
    A little overview
    UV Red Plexi *love*
    The spons from Bilxtra a fake bulgin buttom, cost much less and looks almost the same. Gonna use this one as a start buttom BTW ;)
    Then i marked the plexi for cutting
    Ohhh, the button after polsing it *love*
    Then I cutted the plexi.
    Almost straight! :rock:
    Then i cutted the rest, used a beltsander, p180, p240 and p1200 sandingpaper.
    Any comments?
    Discussion tread
  7. Klekkus
    5 Nov 2005
    Update 03.03
    Painted the door with some primer.
    The i started sandin the MOBO-plate
    Then i started drawing and drilling the fanhole.
    The i drilled and sanded the fanhole.
    Then i started the make the old front dissapear
    After cutting and sanding
    Looks okey? ony issing the hole for the Power button and the optical drive.
    The finish before i the clearcoat
    The bottom og the case, you cant see the nice finish on the picture xD
    And the sidedoor :waah: I had too sand it to get rid of some ugly "dots" and I did'nt clean it enough.
    The toppwindow :naughty:
    Any comments?
    Discussion tread
  8. Klekkus
    5 Nov 2005
    5 updates and no comments, :waah: what did I do wrong?
  9. Klekkus
    5 Nov 2005
    Update 04.03
    Drilled holes and screwed in the bolt for the front
    Looks okey?
    Then i turned it around and screwed the bolts in.
    Power drill! :twisted:
    Some plexi dust :p
    Then i sanded the hole with this bit on the dremel
    Looks lik eit was i bit could in the basement today
    Bigger Picture
    A little overall from today.
    Any Comments?
    Discussion tread
  10. Klekkus
    5 Nov 2005
    Update 16.03
    Damn, the plexi are too big for the window :waah:
    Think I'll need to cut it again.
    I ran out of paint, so the finsh are lousy. Think I'll sand it down and paint it again.
    Same problem, too little paint!
    Then I'l have to sand the inside and outside, and then i "pop" the pices together :D
    Please, feel free to comment. This is the 8th update, and I got no comments. :( Discussion tread
  11. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Haha, you have taken the wrong link in your last update at least, to the discuss thread, we ends up in the Black Pearl Discuss :p
    But very nice work, i haven't posted here because i'd followed it @diskusjon, you're doing excelent work there to ;)
    I love the Red UV Plexi just to much, cant wait to use it in my later Mod=) But the sleeves, have you tried it in UV? Some say it will be more like orangeyellow?
    KUTGW!
    Øyvind
  12. Klekkus
    5 Nov 2005
    Hehe, I fixed the link problem ;) Haha, discuss the Black Pearl then :lol:
    Thanks, it's not so easy too almost finish a mod in only a week :D
    Ohh, oh yeah the Uv red Plexi are awsome! looks ewen better in real life :thumb: Well, I might have to test the sleeves under some Uv light.
    Thanks again ;)
  13. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I like your idea. But I think you are going to have a hard time filling the holes at the bottom of the window. Why not cut the right off?
  14. Klekkus
    5 Nov 2005
    Thanks.
    Well, I'll try my best. But if i cut it of I think the window will look too big. So I'll might have to stich to bondo then :p
  15. mattthegamer463
    26 Nov 2004
    Nice job buddy! :thumb:
    One concern about it though. Is it still fairly strong and structurally sound with all that metal cut out? I guess the plexi helps, but that may not be enough. My way to test if a case is strong enough is by sitting on it. If it bends or I can feel it being strained by the weight I know its not a very sturdy case. These are usually the paper thin ones, like the one Im using for Project PCB, which was a mistake. Oh well, live and learn. Keep up the good work though, Chris.
  16. Klekkus
    5 Nov 2005
    Update 22.03
    I cuted the plexi wrong :wallbash: now it's to small for the window :waah: Think I need to buy a new plexi plate!
    The combination with white and red :thumb:
    Lovely UV light: :rock:
    I also drawed the HDD-"cases" in SketchUp:
    Without HDD's
    With HDD's, BTW it's 1cm between the disk's. Might have to change it too 2cm.
    How I'm going to lift the cases off the ground^^
    Any Comments?
    Discussion tread
  17. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Looking good, very very good! :D
  18. Klekkus
    5 Nov 2005
    Thanks :D Like the UV red plexi? :naughty:
  19. Klekkus
    5 Nov 2005
    Thanks, WTF? how could I have missed this comment? :S
    Well the front are steady! I have to test it a little more, but It not so thin. But I have to "pop" the case togetter first then ^^ Thanks for the tip, but the plexi should replace the old metal.
  20. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Hey, looks like a nice project so far. Where did you get the red plexi glass?
    And what do you say when you want a company to sponsor your mod? I tried to get a few companies to sponsor my 1970s-PC (link in sig.), but they all said no. Looks like every other Norwegian modder gets sponsors, though...
