Good evening friends ! Finally today I was able to get the mod. Today I've been painting the rest of the fans and 2 pieces of RL ( T & valve ). The Nidec ... The Noiseblocker ( In photo only taken 4 but were 10 in total) Then I have started with the upper radiator support . Now I will not have problems if you want to get the upper filters. Some cuts in the original top piece to anchor the support ... And placed bracket with the radiator ... Side view, the guides I've put them rivets , so is much safer . Top view ... Tomorrow I rise up early and I'll get back again to work . A greeting!
Good evening friends. As comment and given the success with backplates, prices and giving me problems with letters, in the end I decided hacermelas myself. They are simple, but they love me as they have been. Pre-trimmed and sanded, and presenting them to the GPU ... And here already screwed ... That's all for now, hope to catch soon (I get much stick) with the wiring of the fans ... Greetings and Merry Christmas!!!
Good evening friends. I bring a new acquisitions today. It would have been better in blue but the quality and features have made me sacrificing illumination. (Will inquire if you can change the lighting in blue) I present to Razer Taipan! The old Razer Diamonback 3G and Young Taipan Without the Razer software, as such, the wheel is always lit and the logo turns off and lights up slowly, like a heartbeat ... A greeting!
Good evening friends. Today I've been and I've been wanting to get for a while ... So there are advances First I open the mouse to see what had led ... bad luck, led back normal , the wheel is a plate with micro pcb leds smds ... So unlucky ... Today I bought screws M3x6 black star, allen you'll quickly passed . Moreover, even bringing the box rust, imagine if on top has a wet environment RL ... Now I have also purchased the LED strips , 2m blue and 1 white ... I already have the cable ready for the front fans and placed the ventis , filters and cables ready to connect And I made two small modifications to the upper guides to the radiator. Removed rivets and screws placed , so you can adjust the height and colocaqcion vinyl . The result is obvious Finally I have started with the cable upper radiator. 6 ventis ! I already have a cable with 3 ... Foul other and merge 2 ... more Tomorrow I hope to progress a little more for the cable end ... A greeting!
Good night. This afternoon I put another little while and I finished 6 shots and cable sheathing the nidecs. And nidecs Tomorrow to see if I can make the cable for nidecks ... A greeting!
Hi!!! Very tired after a day's work and then with the mod, but comfortable . I just picked up all our gear . Finishing the cable to the rear double Nidecs and after that , the test . Checking all ventis with cables ... The result ... A little scare, one Nidec not work. Identified the fault, wrong order of the wires in the connector ... ALL FANS AT 100 %! I have that weight lifted off because the gigs have been good measure, do sleeving and welding ... The welder I have not warmed much in the end and I 've seen and wanted to solder the wires to the strip, above points are very close ... After that I have started with white LED strips. I cut two pieces of 5cm with 3 leds , cable, solder sleeve and ... Where? In the first time I go to put the cable with 2 leds of the switch first, I 've reused cables and wuala !!! Unlucky PCB blank , if black would already perfect . To light switch will use the front switch brings the 810 you save it as you know. Tomorrow if I can ... more
I've had some kinks to carry the rear rad tubes that acts between gpus and cpu ... At the end I solved this way: Fan out ... And the tubes or crossed ... Once fixed this , Unused I needed to put the flowmeter , therefore, all the RL and testing it mounted adapter. In the first half hour ... leakage ups ! ! Nothing an extension board with very little to no pressure on the T. Changed and back on track . To clean the circuit , distilled water, vinegar, and h7 Viakal ... I think anything that resists lol ... This is nothing compared to what has been busy ... I had to drain and refill the circuit does not know how many times I've lost count ... Now , **** through a tube ... Said this a photo of the current state ... The front with LEDs already placed , is like the original ... Detail drain, and almost entire points except the cpu, the bracket of the gpus and aquaero remains a tad lower empties the top of depo ... For Poweradjust I used the original cover to dock it , so yes, no holes, double sided tape and a craft deck methacrylate and ready ... Supports that I have managed to set the valves to remove the filter are that the circuit is empty . These are acrylic , but departed one and made of aluminum .. And an overview ... That's all folks , this weekend has spread much , if not for the time I 've thrown up your ass would have more rad ... A greeting!
Well, I have made changes. I hope you enjoy it, I just love how I have been, but clear the box and released the front tube with the filter that did not quite like it. First of all, Fittings Unused me ... The pump after changing the adhesive foam rubber sponge to buy today ... And changes in the RL I have to change the tube on the graph to the upper rad because I've been a little short, a little forced and this is not good ... Tomorrow will do the change this and much more ... I have another week full dedication A greeting!
Good night, almost days . The holiday week is given on whether and I have not dedicated 100%. I bring more progress I 've made acrylic panels to hide the "ugly " the pc ... These panels can be removed and replaced very easily. The velcro adhesive tape is to blame Now new acquisitions a more poweradjust and the front in black . And as cable manufacturing the front ... After connecting all wiring (less than the power supply ) to the motherboard , I have started to work with the lighting . I knew the Aquaero can handle using 2 channels having other accessories , including the LED strips. Panel a little tinkering I managed to find the operation . I can adjust the intensity from 0 (off ) to 100% ( maximum) . I have also turned blue filter to lcd adhesive aquaero . Tomorrow another while and if all goes well , the montage is successfully completed , finally! ! We will check the status of hardware ... I hope I do not take no surprise , again ...
Mod Finished!!!! Finally finished the mod, get some nonsense , but I have to find some pieces , when you find the colocare but is a minudez . Now we just turn on and check that the hard work as you run , install and configure everything that is no small feat ... Had said the action of the evolution of day Lined front panels and placement of LEDs ... Place this and some cable that was outstanding ... We spent the interior ... The surplus of the anticyclone ... Meet your luxury ! We spent abroad. The back , which leads mia mother ... Removes much pon pon, but the end result I like .. Back Front Detail Vision of the whole box without side panel ... With the side window panel... I promise more photos maintained and lighting . Today I have no time for anything more and more . I hope you liked it ... A greeting!
Final photos Videos [video=youtube_share;qnlTYTPntpM]http://youtu.be/qnlTYTPntpM[/video] [video=youtube_share;BYXOwp0OnRU]http://youtu.be/BYXOwp0OnRU[/video]
