Modding Bolt M numbers
Discussion in 'Modding' started by Kalym, 1 Mar 2002.
  1. Kalym
    Kalym What's a Dremel?
    18 Feb 2002
    Does anyone know what the M numbers are for nuts and bolts?
    I'm actually after 3mm nuts and bolts, but all I can find are nuts and bolts with M nubers (M3, M4 etc)
    Not sure if this is the hole size or the closeness of the thread, or the length of the bolt.
  2. Flibster
    Flibster What's a Dremel?
    9 Nov 2001
    You need M3 then. Not entirely sure what all that means but....
    The outer edge of the threaded component +0.1mm *ish* =M number
    Hope that helps.
    Simon/~Flibster
  3. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Pointless spam I know, but top signature, Flibster!:D
  4. macroman
    macroman The One
    3 Sep 2001
    M3 = 3mm, M4 = 4mm etc.. That refers to the thread there is also a length.
    M3 x 25 = 3mm bolt 25mm long.
