Other Bonding ABS plastic to MDF
Discussion in 'General' started by silk186, 1 Mar 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I bought ordered a desk from Amazon that was in "Used - Very Good" condition and was struggling to figure out why the lamp wasn't staying up. A bit of looking around and I realised why it was returned.
    I'm thinking to ask for compensation and repairing it myself as it's 19kg and I chopped up the box and packing material already. I'm not sure what is the best way to bond the pink ABS cap to the MDF cutout. I'm thinking maybe glue gun, gorilla glue or epoxy. I figure a modding community is the best place to ask.
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
    I would gorilla it. Deffo ask for some compo if it wasn't mentioned.
  3. legoman
    legoman breaker of things
    28 Feb 2010
    Yeah gorilla or an epoxy on it
    silk186 likes this.
  4. silk186
    silk186 Derp
    1 Dec 2014
    I wish "the best/most suitable adhesive" was easier to understand.
    I ordered some sandpaper to rough up the plastic.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    JB weld. But that's my answer to all of lifes "broken" problems.
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Drill two holes and glue and screw it together.
  7. silk186
    silk186 Derp
    1 Dec 2014
    I was thinking about trying a nut and bolt with a washer but would want an adhesive as well.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Two part epoxy. Light sand of the ABS, thorough degrease with IPA (or Acetone, but be fast or it will melt the ABS!).
    Gorilla Glue (Polyurethane) will also work, but you will need to clamp the plastic piece in place to stop the expanding glue pushing it out.
  9. silk186
    silk186 Derp
    1 Dec 2014
    Will nail polish remover work the same?
  10. edzieba
    14 Jan 2009
    That should do.
  11. Goatee
    Goatee Multimodder
    19 Apr 2015
    This should be default advice for all adhesive based jobs.
    silk186 likes this.
  12. silk186
    silk186 Derp
    1 Dec 2014
    Is this the best option for this and general use?
  13. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I've only ever had good results with JB weld, although it flattens out more than I would have expected, it sets solid and with a real bite.
    For this application, I expect that any two part epoxy properly applied will be more than strong enough.
    silk186 likes this.
  14. edzieba
    14 Jan 2009
    JB-weld is fine, not the absolute greatest bond strength or price/volume, but easily available and no fancy prep/storage/handling needed.
    This.
