Modding Bondo UK Supplier?
Discussion in 'Modding' started by Lazlow, 4 Jun 2006.
  1. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Simple question - I've scoured the forums and google, but I'm having trouble finding a UK supplier for Bondo. Either I'm not looking hard enough, or it is a US only product...
    Anyone know anywhere in the UK that sells Bondo Body Filler? Or at least a similar product to fill in plastic/metal parts on a mod. Online, or high-street retailer?
    Many thanks!
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    It isn't called bondo over here and you can by it from helfrauds or any automotive repair shop.
    Its called P38 body filler.
  3. Lazlow
    8 Aug 2003
    Aha, that would explain why I couldn't find it. Thanks for the info AJB2K3!
  4. AJB2K3
    12 Dec 2005
    No problem.
    The only reason i know what its called is because i had it out to fill a hole in my car after debadging.
  5. $loth
    $loth What's a Dremel?
    4 Jun 2006
    I've got something called 'Ready Mixed Filler' from B+Q for £3 (you get 750g). I've used it to fill some tear ups on the plastic front of my chieftec and it's quite good stuff,nice and smooth once sanded!
  6. Lazlow
    8 Aug 2003
    Thanks for the heads up! I've got a B&Q about a mile away, so will look for it sometime this week. I just want something to fill in the grooves on a current mod of mine.
  7. Lazlow
    8 Aug 2003
    Wish I had written the name down. I spent 15 minutes staring at the filler section in B&Q, but couldn't see anything suitable. Will head over sometime this week and look again...
  8. AJB2K3
    12 Dec 2005
    Don't use filler its plaster based.
    Go for the body filler from helfrauds or any car body shop (hickney valton)
  9. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    if i were you i would use P40 as a base, then use loctite body filler (also available from halfords) to smooth it off for painting :)
  10. kempez
    kempez modding again!
    4 Aug 2005
    The body filler from Halfords should do the job. We used to use that to finish off our car audio installs :)
  11. Lazlow
    8 Aug 2003
    Thanks for all the recommendations to Halfords - I'll check them out before the weekend!
  12. Fatboy
    Fatboy Bored
    8 Oct 2001
    Isopon P40 for more structural work , P38 for the usual and then oyu will want some spot filler for the tiny tiny holes and stuff.
  13. Lazlow
    8 Aug 2003
    Picked up a twin pack (P38 and P40) for just under a 'tenner. So far so good - works really well!
