Bonzanego's Project: MorningStar
Discussion in 'Project Logs' started by bonzanego, 20 Aug 2005.
  1. bonzanego
    bonzanego New Member
    5 May 2005
    Since the true purpose of this machine is to be a HTPC I am trying to aquire a wireless keyboard and logitech trackball mouse that will be matched to the case.
  2. MetricOClock
    MetricOClock New Member
    19 Aug 2005
    holy freaking sweet, i love the art deco almost theme , keep up the good work
  3. Pitbull
    Pitbull New Member
    20 Mar 2005
    Pfff nice work dude
  4. bonzanego
    5 May 2005
    The bezel for this project has proven much easier than that of the Satan's deuce project. ( you would never guess looking at the bezel it was made from paper and cardboard molds) There are fewer angles and curves to worry about getting straight. The only tricky part is getting the inner curve of the leading edge to match up all the way around, a big round file helps accomplish that. The part is pictured here with only a light sanding, there is still more material to remove around the leading edge and final sanding to line up the seams where the bezel meets the case body. The mold was nearly perfect so the seams will only require very minor touching up.
    It is very importain that the inside of the bezel be perfectly round so the turbine blades turn freely and leave a uniform gap at thier edge.
  5. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    This is simply fantastic - I love the lines that this has from the base, very sweet. You mentioned that you cast the support in urethane - how is this done? I am really impressed by this!
  6. TheEclypse
    TheEclypse New Member
    11 Aug 2003
  7. Pete_Venkman
    Pete_Venkman New Member
    20 Jul 2005
    :jawdrop:
    Homina homina homina...that looks so awesome already! I can't wait to see it with the blades in the front.
    :rock:
  8. LOTTARO
    LOTTARO New Member
    1 Jul 2005
    OMFG!
    This is art!
    Artistic aplicated to mod!
    Art Attack (disney program) is a POROTO compears to this work!
  9. Isuo
    Isuo New Member
    13 Oct 2004
    Incredible! It looks really sleek.
    Btw, the highlites from the plan were a clever idea.
    I know you really can't say like that, but I don't know how to say it correctly.
  10. bonzanego
    5 May 2005
    Thanks for all the compliments folks I think you will like this project even more as it gets closer to completion.
    The tail of the turbine is roughed out now. The steep angle made this piece much more difficult to create than the bezel.
    There is still quite a bit of surface sanding to be done on both pieces to make all the seams even. The exhaust tube is next and it is mounted inside the tail section as pictured in the drawing.
    As I get closer to completeing the body of MornignStar I am trying to decide what to make the turbone blades out of. Plastic and metal are obvious choices, but I was thinking about making them from wood to match the base. The wood is an unexpected material and would compliment the base, have to think about it more as it gets closer to time to make the parts.
  11. Fozzy
    Fozzy New Member
    25 Jan 2005
    Plus, if you use wood you could probably find a an airplan propeller that will fit perfectly and work great.
  12. mondriaan
    mondriaan New Member
    20 Aug 2004
    WOW :jawdrop: how do you come up with these ideas.
    Keep it up :thumb:
  13. TheEclypse
    11 Aug 2003
    Whats happening with this one? Updates!
  14. paradigmqc
    paradigmqc New Member
    20 Jul 2004
    this is NO LAN casemod :)
  15. PA!N
    PA!N New Member
    16 Jul 2005
    Wow wicked desinge Dude :thumb:
  16. r00t69
    r00t69 New Member
    2 Apr 2005
    Superb, looking forward to seeing the progress.
  17. D B
    D B New Member
    11 Apr 2004
    Going to be Beautiful , and if you can make the turbine blades out of wood it would look fantastic .. I can see it in my head, the curved wooden blades would be almost sensual
    I like the smooth , natural wood / high tech turbine contrast
    A beautiful piece of art for sure
    DB
  18. bonzanego
    5 May 2005
    Thanks everyone, I am still moving along on this project and actually have the front door hinged to the body now and the entire thing sanded smooth and to shape. I just have zero time to do the updates these last 2 weeks. I am going to try and get the project logs caught up this weekend.
  19. JavaDog
    JavaDog New Member
    13 Mar 2004
    In the immortal words of Peter Griffin - "Friggin' Sweet!"
  20. Goth
    Goth New Member
    17 Oct 2004
    this is the most coolest//awesomest mod ive seen in this life (ive seen alot of very cool//expensive mods with my own eye)
