booting xp from external hd?
Discussion in 'Hardware' started by exavier412, 8 Dec 2007.
  1. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    Hi, I'm wondering what is necessary in order to boot into xp from an external HD. I'm trying to set up an older (XP 2000+, Gigabyte GA-7VAXP) computer just for fun. the thing is, I currently use the hard drive (it's partioned) as a place to backup media and stuff for my mac.
    I have Windows on a small partition, and my backup stuff on a larger partition. Do you think it would be better to access the backup partition from my mac via the network or just unplug the external hd enclosure fom the PC and plug it into the mac? I guess that it would be easier to just run it through the network, negating the need for me to use an external HD enclosure. Is this true?
    Let me know what you think the recommended process for doing this is.
    If you need me to clear something up, just let me know.
  2. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    booting from an external drive depends on the BIOS. I don't know about having a mac and Windows partition and booting from it. I haven't had good luck with just using them (without booting off them) partitioned that way. if you could format the whole drive windows, then just share to the mac, that would work except for things like video editing.
  3. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Unless the external drive is e-SATA and you plan to use it.. put the Hd in the PC and let the Mac network... Because even with USB 2.0 or Firewire, XP is going to run like a sleep deprived snail because of the slow interconnect speed and the added latency of going through the externals controller....
    It would also remove the issues of if your mobo even allows booting from an external.
  4. GoodBytes
    20 Jan 2007
    I hope that your external HDD has eSATA... 'cause trough USB... it MIGHT be slow, specially that generally those external hdd's turn at 5400 rpm.
